Totally bypasses the onboard charger. Of course, you also need the CHAdeMO adapter.If you lived near me I would let you try my CHADeMo - not sure if it uses the onboard on not.. does it?
At least on my car, glowing blue indicates the car sees the UMC, but that the scheduling says it's not time to charge yet. If it doesn't see/connect to the UMC, it will either not glow at all or turn orange or red.Since it glows blue even when the plug is connected, it seems like the car is not seeing that the UMC is connected.
Am going to hope it doesn't drop too low in charge before Tesla service is back on Tuesday....
The battery heater running is rough. You can save a little juice by putting it in range mode (which will limit pack heating) and energy saver mode with always connected unchecked. If you have a 12V battery tender, can't hurt to throw that on there to mitigate 12V draw and save a couple %.
I think you probably wanted to pull fuse 53 in box 2, not 44.
I have a similar problem. The connection on your car is likely suboptimal. My car charges with supercharger and portable plugs fine but not with my HPWC.
Please try multiple reinsertion a and torquing / pushing the charger handle up or POWs or left or right. Hold it steady with pressure while the charging starts. After 60 seconds of green the voltage should be high enough to release.
Why pull the fuse to the BMS (battery management system) ?
It's working, it's keeping the car battery warm in this extremely cold...
