4.5 broke my workflow! (changed unlock procedure)
Discussion in 'Model S: User Interface' started by PattyChuck, Jun 2, 2013.
  1. PattyChuck
    PattyChuck Model S P100D, Model X P90D
    Valparaiso, Indiana
    I used to be able to approach the back of the car, press the trunk release switch (the one right above the license plate) for about a second, and it would unlock the car (extending the handles) without opening the rear hatch. After upgrading to 4.5, the trunk now opens. Does anyone know of a "workaround" for this? I'm usually approaching my car with my toddler in one arm, and a school bag in the other, so digging in my pocket for a key is difficult.
    I know, I know, this is a really silly gripe, and the rear hatch now functions as it was probably intended to, but if anyone knows of a way to unlock the doors by approaching the rear of the car without having to press the button on the keyfob, I'd love to hear it.
    I've attached a relevant xkcd before anyone else does :biggrin:
  2. Jason S
    Jason S Model S Sig Perf (P85)
    Rocklin, CA
    That is indeed the xkcd that came to mind.
    ... only workaround I can think of is to take the few steps towards the front.
  3. FlasherZ
    Yes, you have to do the "two-step shimmy" toward the front of the car, then back to the rear again. :)
  4. ckessel
    ckessel Active Member
    I don't understand, why hold the rear lift handle for a second to unlock it, but not want to raise it? What's the point?
    If the goal is to get the rear door handles to extend, why is pausing and using a hand to hold the rear handle for second better than just stepping 3 feet closer to the front door to get it to detect your key? Seems like that'd be faster anyway.
  5. GeekGirls
    GeekGirls Kid in Candy Store
    Seattle
    In my case, the point is to get the car to unlock so I can remove the charging cable. I back into my garage, so the car doesn't unlock as I approach it from behind – and you can't remove the charge cable until you've unlocked the car. Fumbling in my purse for the fob is an inelegant solution, as is having to do the shimmy described above. I'm not thrilled about this change.
  6. dbfish
    dbfish Member
    Sacramento, CA
    Foot switch attached to an arduino board to run an API call to unlock the car. Hah, I should sell that.
  7. CapitalistOppressor
    CapitalistOppressor Active Member
    Wasn't the button press method listed in the "cool features you probably don't know about" thread? I can see folks not being happy about changing that, lol.
  8. kendallpb
    kendallpb Model S: P 8061
    MD, USA
    Pressing the trunk release switch on the car (which I only found out about within the past couple of weeks) used to not operate the trunk? I've never heard of this...wow. Was this just your car or was this an actual feature that Tesla documented and others also experienced? I thought I'd read every thread on every obscure little feature here--I guess not!
  9. jomo25
    jomo25 Active Member
    Scottsdale, AZ
    Long pressing it when the car is locked would unlock/present the handles. Another press woudl then open the trunk. If the car was already unlocked, then a single press open the trunk
  10. ckessel
    I can certainly understand having one's routine. To be honest, I'm still not sure how having to have a hand free and hold the button for a second is faster/easier than just walking 5 feet towards the front door, but we all have our preferences.
  11. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    I would be happy with it simply unlatching the charge cable when the trunk opens. The handles could extend when I approached the driver door.
  12. MikeK
    MikeK R#129, TSLA shareholder
    San Francisco Bay Area
    I'm sorry about your workflow, but this change sure improved mine! :)
  13. PattyChuck
    Valparaiso, Indiana
    Yes, this is also part of the reason why I don't like this change. It'd be really super nice if Tesla was able to update the software to where pressing the button on the charging cable would detect if the keyfob was in your possession thus unlocking at least the charging cable, if not the doors as well.
  14. defmonk
    defmonk Member
    Marina del Rey, CA
    PattyChuck, I think that would be an excellent feature. It's annoying to have to try to get the car to see the key fob, when all I want to do is just remove the charging cable. Another benefit is by lowering the "friction" of removing the charging cable, the more likely that folks will extend the courtesy of timely removing the cable at public charging stations.
  15. kendallpb
    MD, USA
    Great idea! I still forget this periodically at home, and try to remove it before going up (or tapping the fob button).
  16. strider
    strider Active Member
    NE Oklahoma
    If you can get a hand into your pocket to long-click the trunk button, why not just double-click the top (unlock button) instead? Can't see how that's any more effort.
  17. teslasguy
    teslasguy MSP P#1117
    West Chester, Pa
    I use the trunk unlock button method all the time to remove my charge cable. Instead of walking to the car door and then shaking my leg at the handle (not kidding!) I just touch the trunk unlock button and the car unlocks. Don't have to touch the key or shake my leg. :)
    Sent from my iPad using Tapatalk HD
  18. AnOutsider
    AnOutsider S532 # XS27
    This, I need to see.
  19. stevezzzz
    stevezzzz R;SigS;P85D;SigX;S90D;XP100D;3LR
    Colorado
    I'm with the OP: I like the way it used to work, before 4.5, and for the same reasons. The "Tesla Two-Step" is awkward and inefficient, at best; and double-clicking the top fob button through my pants is a PITA.
    I like PattyChuck's suggestion even better than the old behavior, though.
  20. derekt75
    derekt75 Member
    San Jose, CA
    I often used the hatch button to unlock the car. Sometimes it really is more convenient than any other available method.
    What I don't understand, though, is why the car doesn't auto-unlock when I'm right next to it. I wish the auto-unlock range were several times larger than it is. and directly_in_front_of_the_car isn't as useful as right_next_to_the_rear_door.
    This is my #2 frustration with the car.
