4 vs 8 camera, rear-view and blind spot detection
Discussion in 'Model S' started by ND100, Oct 20, 2016.
Tags:
  1. ND100
    ND100 Member
    NSW
    With today's announced updates, tesla.com/autopilot refers to a total of 8 cameras.
    The Model S ordering page makes it clear that "Enhanced Autopilot" comes with 4 cameras. "Full Self-Driving Capability" unlocks the other 4.
    What's not mentioned is which 4 are in Enhanced Autopilot. I'm assuming that these 4 are the 3 front facing, and the rear-view which is now used for Enhanced Autopilot.
    I'm curious how (if at all) this improves blindspot detection. It seems like a combination of rear-view and improved ultrasonics could make a real difference here.
    What's confusing to me is that this is described (on the order page) as helping to "see fast-approaching vehicles in adjacent lanes". For this to be optimal, you'd presumably want the "Rearward-Looking Side Cameras" that cover a larger arc and distance.
    Anyone heard anything definitive from Tesla on this?
  2. S4WRXTTCS
    S4WRXTTCS Active Member
    Snohomish, WA
    Makes absolutely zero sense to me.
    Why change the number of cameras that are enabled when all the cameras are going to be there anyways.
    Right now the side-spot monitoring is greatly hindered by the ultrasonics. Even if they had more that are better it won't fix the problem. The only way to fix the problem fully is to have camera's, but I don't see how they would have any for the sides with a 4 camera setup.
  3. ND100
    ND100 Member
    NSW
    One possible 'out' Tesla have here is they describe "Side Collision Warning" as a "Standard Safety Feature". It doesn't make sense to have a worse performing safety feature just because "Full Self-Driving" isn't purchased. So, maybe they'd actually enable those cameras for that purpose only.
    I guess when cars are shipping it'll be easy to verify by covering those side facing cameras and assessing the difference.
    It'll be interesting to see how these 'double range' ultrasonics work when coupled with rear facing cameras (either single or the set of 3). Others like Mercedes have fantastic blind spot monitoring with radar.
  4. krazineurons
    krazineurons krazineurons
    Redmond, wa
    The way i understood it was that it actually fits additional cameras only if you go full self driving mode. Is it confirmed that it is a software unlock only?
  5. gearchruncher
    gearchruncher Member
    Seattle, WA
    Given you can install it after delivery for $1000 more, the assumption is that it's a software unlock.
  6. Bilen
    Bilen Member
    Denmark
    On the conf call Elon said that all the hardware is in all new cars.
  7. David29
    David29 Active Member
    DEDHAM, MA
    So in other words, the cheapest one can get any form of what used to be called Autopilot is now $5000 whereas it was $2500 when i got my car. Wow. Stiff increase even though the features are better.
    And the further upgrade to full autonomy is "only" $3000 more. Seems to me that next increment would be worth more than the lower level functionality -- So I'd have expected the prices to be more like $3000 for the basic package and $5000 for the fully autonomous.
    I hope there is a less expensive version available for Model 3....even if it has to have fewer capabilities.
  8. MP3Mike
    MP3Mike Active Member
    Oregon
    I assume the four cameras are the main Front camera, the two side rear facing cameras, and then either the rear camera or one of the additional front cameras. The additional four cameras provide a little more coverage and redundancy so that even if one camera gets too dirty to be usable the car can still continue. (But maybe with limited functionality depending on which camera goes out.)
  9. Xminus6
    Xminus6 Member
    Bay Area, CA
    The language they use around the 8 cameras is "active" cameras. It seems all the cameras are installed and only some of them are activated based on the software package you purchase.
  10. Bilen
    Bilen Member
    Denmark
    That seems like a very good assumption. Especially since the Design studio under Enhanced Autopilot says:
    Qoute
    ... and to see fast-approaching vehicles in adjacent lanes.
    End-Qoute
    That will require the two side rear facing cameras.
  11. andrewket
    andrewket Well-Known Member
    I wouldn't concentrate too much on which features use which sensors, unless you're doing so out of technical curiosity. Imho, the better way to look at it is that it costs $5k for one set of features (A), and $3k for an additional set (B), and you must buy A to buy B.
  12. ND100
    ND100 Member
    NSW
    Both technical curiosity and whether to cancel a built-but-not-yet-delivered car and reorder, in large part to get better blind spot detection.
  13. Gregkeys
    Gregkeys Member
    So the enhanced says your going from 1 to 4 camera's does this mean AP1.0 is now included standard?
  14. gizmoboy
    gizmoboy Member
    Rancho Palos Verdes, CA
    No reason to believe that.
    They are using Enhanced to distinguish it from "original" autopilot, not to imply you get "unenhanced" AutoPilot standard.
  15. Gregkeys
    Gregkeys Member
    What about the going from one camera to four? There is no option for one camera which suggests, to me anyways that it's included?
  16. MP3Mike
    Oregon
    Only for people that ordered the old AP package before the announcement. (Of course if the take rate is too low on the Enhanced level they could bring back an AP Classic level that is cheaper.)
  17. Gregkeys
    Gregkeys Member
    Would have communicated better if they left out the who one camera part so that it read something like "The enhancements include four cameras to see fast-approaching vehicles in adjacent lanes."
  18. mgboyes
    mgboyes Member
    United Kingdom
    tbh I'm assuming that's just marketing spin designed to drive upsell of the full autonomy option.
    No reason to believe they will actually choose not to use the data from the 4 side cameras in order to give the best implementation of autopilot features like blind spot detect - that would just be making their developers' jobs unncessarily harder.
    Every car that supports enhanced AP is going to have 8 cameras, so why not use the 8 feeds if it makes the implementation easier?
  19. Lesifass
    Lesifass Member
    Germany
    Yeah, and imagine the headlines. "Tesla AP crashed into $OBSTACLE after failing to recognize lane markings because cameras 2, 3, 6 and 7 are disabled by software". I don't think they really ignore those 4 camera inputs. It makes no sense. They should (and I hope they do) simply disable the self-driving features when not on a freeway, which appears to match the described difference in functionality. Oh, and add some nags to keep hands on wheel.
  20. Saghost
    Saghost Active Member
    Delaware
    One camera is needed for the AP safety features that have been in every Tesla for two years now - automatic emergency braking, forward collision warning, etc. I'm site those things will continue to be standard (once the firmware update to enable them goes out, anyway.)
    I don't see any reason to believe you'll get what until recently were called Autopilot Convenience Features running on that one camera, though.
