Hi all,
For my winter setup I decided to buy a second set of wheels and TPMS sensors so I could do the changeover myself.
The TPMS sensors were easy: I found a set of four specifically intended for the Model 3 that are well-reviewed
on Amazon for $119, here.
So now I just have to find a set of wheels. I really only care about two things when it comes to winter wheels: that they fit, and that they're cheap. I would honestly buy a set of $25 steel wheels if I could find them in the right size.
Discount Tire (which I've found to have generally lower prices than Tire Rack), has
this list of 18" wheels compatible with the Model 3 (non-P).
The ones I'm looking at are:
Vision Cross II ($115, 28.2 lbs)
X Wheels ER-1 ($116, 25.4 lbs)
Liquid Metal Shift ($123, 26.4 lbs)
Velox Nirvana ($128, 28.0 lbs)
They all have the right bolt pattern and offset, sufficient load rating, and sufficient center bore (they're all 73.1mm center bores vs. the Model 3's 64.1mm bore).
The things I'm not sure about (which Discount Tire doesn't list) are backspacing and lug style. Discount Tire says these wheels "fit" the Model 3, but does that mean they have the same backspacing and lug style?
Any wisdom here (or comments on those wheels of any sort) is greatly appreciated!
