Air Conditioning Blowing Hot Air
Discussion in 'Model S' started by davie_100, Jun 20, 2016.
  1. rcsting
    rcsting Member
    Sacramento , Ca
    This has also happened to my refresh 75D twice in the last 2 weeks. Tried to reboot with no luck. The A/C worked normal after the car was parked and powered off for a bit.
    Will definately contact Tesla is this happens again.
  2. Matt279139
    Matt279139 New Member
    Dundee
    Hi ZBB. Here is something you won't come across every day...depending on which model you have, I'm the actual person who built and tested your air con system (prior to installation) at Eberspacher uk in Ringwood. The air con unit is basically the same as in any other car. My advice is to get it regased. All the components (drier, condenser, compressor etc) are sealed and tested to 30 bar prior to shipping but over time, as with any car, the system may lose integrity. A regas process will determine if there is a leak and with what component. By the way, when I left Eberspacher back in 2010 we were still ironing out the wrinkles such as the air con wiping out the radio.....did they actually manage to sort that out?!! ☺ we had fun with the preproduction model. It's a lovely thing to drive. Good luck and I hope it gets sorted out. By the way, look for the initials MH and a date on a little sticker on the control unit....that's me ☺
  3. tphillips444
    tphillips444 New Member
    Phoenix
    Well I can say that this happened to me and was very bad very dangerous, was driving back from Cali to phoenix on the i-10 in august, outside temp 110, about an hour from phoenix no cool air started to come out so I pulled over at a gas station as everyone including my 2.5 year old and 6 week old was sweating/over heating. Called SC while we waiting in gas station they couldn't find anything, got back in the car and drove for about 30 mins everything was ok then all of a sudden no cool air and we had to pull over again. Waited and called SC again but they still couldn't find anything. Obviously with an interior temp of 100+ and 2 little ones in the car in a very remote area of AZ we were lucky that we could pull over and stop somewhere with AC as there are 40 to 50 mile stretches of nothing but hot desert there. Took it into new tempe SC and they had it for a few days and said that they replaced the battery chiller and TXV Assembly but was kind of seemed fishy as they originally said that they couldn't find anything. Fast forward to about 2 weeks ago and again no cool air, cabin temp 100. Wife and I fiddled with the setting but nothing worked except leaving the car off for 20 minutes and coming back to it. Not sure what to do, I feel that if I take it into SC they will just say the same thing. Not sure how an AC can work and then not work and then start working again? Never had a car have this even close and I have driven a lot of them over the years. After the first incident wife thought I should get legal with them as their is obviously something tech inside of the car that is failing, no warning lights ect. We drive out to cali a lot especially in the summer but a little leary of doing that now with this car which is not good.
  4. Spidy
    Spidy Active Member
    EU
    It might dedicate the cooling to the battery, as far as I understand Tesla prioritizes that over the passengers. Once you stop it cools down the battery enough so the AC is available to passengers again. (Just a guess.)
  5. proxy
    proxy Member
    San Jose
    I ended up on this thread because I'm experiencing this in my late 2016 delivery S.
    Two random times it just wouldn't provide cold air. Took it in for servicing and they said nothing showed up in the logs.
    That was about a month ago and I just experienced it again. Earlier today it was pumping out nice crisp cool air. Now nothing.
    Haven't been driving hard or anything. Just small roads around my neighborhood looking at open houses. Temp outside is just under 70 degrees.
  6. Scott216
    Scott216 Member
    New Jersey
    When I had the problem, Tesla found errors in the logs and replaced chiller, thermostatic expansion valve (TXV) and the compressor
  7. houstonian
    houstonian ಠ_ಠ
    Houston. Duh.
    Happened to me earlier today - S60D, Jan 2017 build.
    Called Tesla, tech could not see anything, suggested using the POWER OFF button to force the car off and see if it worked when it came back on. Issue remained. Tech also noted he could see something in the logs over the phone but I did not think to press for the details. Ended the call with him referring the case to my local SC (Houston...duh).
    After hanging up with him I tried to power off the car a few more times and on the 3rd time the AC came back on.
    The IAH SC called about 10m after that and the local tech said there was a known issue with the firmware for AP 2.0 S's which created an error preventing the AC from kicking on. Current work around is to power down complete (again via the POWER BUTTON), wait a few minutes, and then restart. Local tech intimated this would be addressed in the next firmware update.
  8. croman
    croman Active Member
    Chicago, IL
    It was 75F in Chicago today. I finally tested my AC and it worked. The car was fairly hot after sitting the sun. I can't imagine what I would've done with a baby and no AC. Rolling down the windows helps when driving locally but not as useful on a highway.
  9. Blackwater
    Blackwater New Member
    Perth
    I've had the same problem occur about 4 times since my Model S60 was delivered at the end of last year. I've just called the SC in Melbourne Australia and was advised that this is a known software bug which will be fixed in the next release, due within a few weeks. Fingers crossed.
  10. stevenw
    stevenw New Member
    sydney
    Happened to me 2 days after model S60 delivered. Was near SC when it happened (24^ celcius). They tried rebooting nothing fixed in. Booked for service 2 days later when started working again. Do I cancel the service?
  11. georgeNZ60
    georgeNZ60 New Member
    Auckland, New Zealand
    Did you find a solution? Same problem on my S60
  12. Trilliam
    Trilliam Member
    Florida
    I had the same issue on our S60 that was picked up last week. A road ranger came today and replaced the chiller. He indicated that it was a part that he's been replacing often.
  13. navguy12
    navguy12 Member
    Eastern Ontario
    Did the refrigerant in the system have to be recharged when the "chiller" was replaced? Thanks.
  14. Trilliam
    Trilliam Member
    Florida
    We were talking about other things but I believe it was recovered, vacuum tested and then filled back up. He had this with him:
    Premier R-134A Refrigerant Recovery, Recycling, & Recharging
  15. navguy12
    navguy12 Member
    Eastern Ontario
    OK, thanks for the info. I'm going to assume they replaced your evaporator core. I wonder what is causing these evap core failures. Automotive AC systems can often be like witch-craft, one unit will work fine, the next one, with all the same parameters, gives trouble. I wonder if some sort of assembly process contamination is clogging the Tesla/modern equivalent for the (old Ford) expansion valve.
    Anyway, lets hope you are good to go.
    Very cool (no pun intended) that a mobile service was employed to successful deal with this issue. Your car gets to stay in a controlled environment (i.e. your driveway). Cheers.
  16. Trilliam
    Trilliam Member
    Florida
    This is the best image of what I could find that it looked like.
    http://i.imgur.com/2ajxuvB.png
    To me it looks like a plate chiller that brewers use to chill wort. It was the best term I could come up with =)
  17. navguy12
    navguy12 Member
    Eastern Ontario
    If your photo is what it looked like versus the actual part, then I'd say it may have been a (coolant) temperature sensor that meters refrigerant versus the actual evaporator core. Most evap cores, being in the firewall, are a major PITA to remove and replace.
    The connection point of the rubber hoses, and the actual rubber hoses, in the part in the photo, do not appear to be designed for use in the refrigerant loop portion of the system, thus my wild a** guess. Thanks.
  18. Leight
    Leight New Member
    Cardiff
    After 3.5k miles in my 60D and the first bit of "hot" weather - 21 deg celsius - this happened to my car. The a/c was blowing out warm air into an already unbearably hot car - interior temp was 40 deg +!
    Called the SC and they have pushed some firmware to my car which should solve the problem - I will find out in 1 hour and 20 minutes when the update finishes...
    Tesla need to sort this issue out as it seems to be a common occurrence...
  19. timvracer
    timvracer Member
    Los Gatos, CA
    I had this same problem as well. I called Tesla service center, and they said there were some errors in my logs, and to bring it in, so I made an appointment. However, the next morning when I got in the car, it was resolved, and the A/C was back to blowing cold air, and I canceled my appointment. This happened right after my 8.1 upgrade.
  20. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    I wonder if this is the new 17.14.23 that is appearing...
