bhtooefr
Most people that tow need more than 5K# capacity, especially on a long haul (I would never want to tow anywhere near the upper limit of my vehicle).
Most people don't tow. To the point that the correct vehicle for their needs isn't a F-150, it's not even a Ridgeline, it's an AWD (or even 2WD, a lot of people think they need 4WD and ground clearance when they don't) sedan, like a Model 3 or S.
And, a lot of the F-150's tow rating isn't usable due to low payload ratings on the models that people actually buy (loaded crew cabs) - by the time you've put people and stuff in, your towing is heavily limited by tongue weight, to the point that if you seriously want to tow, you need a F-250 or F-350 to get the payload up.
And, realistically, a BEV pickup with good towing will end up being pushed into the Class 2b or Class 3 territory anyway, as the battery would eat too much payload to be useful in the 8500 lbs GVWR Class 2a unless you can get a lot of weight out of somewhere else. (This is actually worse for pickups than semis, because semis can have better control of airflow over and around them.)
