Cybertruck AWD ($50K version) will have the Raven powertrain from the S/X. Those are 18650 cells from Panasonic in Japan. There is also spare capacity on the S/X line right now, since they are down to 1 shift per day. At least all the powertrain components are available in volume now.
Rather difficult to predict. This may be the new trend setting look for the future.I do hope the finished truck's looks will be just a little less stark - it would age a lot better.
Yes, even the most modest 75 KWh Model 3 pack can charge at 250 KW. The larger 100 KWh S/X pack is only limited by its old-style cooling (wiring is trivial, likely already updated in S/X Raven), which will be redone (and likely in common) for Cybertruck.Are you sure about that? The presentation specifically stated that all versions of Cybertruck would be able to charge at 250+kw.
Or are you saying that the limitation in the S/X from charging at 250+kw is not associated with the batteries, but something else?
Imagine these reasons:Disagree with @Artful Dodger, can't imagine why the newest Tesla vehicle would use the oldest battery pack architecture.
Panasonic has spare cell capacity in Japan for 18650s. There is no spare capacity for 2170 cells in Sparks, and with Model Y and Semi coming in 2020, there will not be any spare capacity for a while.Even if Tesla plans for a build rate of merely 100'000 Cybies per annum, only Nevada will be able to supply the cells and packs in sufficient quantity. Let's not forget that the newer cells are more weight-efficient,
But you seem to be stuck on opitimizing the CT as a new product. I promise you Elon is not thinking about that; his primary concern is finding the fastest way to the market with a new product that's better, not perfect.
- They have spare capacity for S/X packs at Fremont
- won't limit Model 3/Y producition if they ship CT AWD 1st
@mongo @AudubonBIt wouldn't be exactly the same though since you can't make cold rolled stainless from a casting. Strength and hardness could be cut in half resulting is thicker/ heavier walls. That said, they could go stainless on the vehicle lines for longevity.
You'll have to do the math on the product mix. Also Panasonic was looking to convert Japanese 18650 lines to 2170 production. You don't do that with a process running at capaciy.Where are you getting information that there is spare 18650 capacity? Yes, Tesla reduced the number of S&Xs that they make but they also eliminated all but the 100kWh versions. (And the smaller packs were the majority of what they were making before.)
There's only 1 shift of S/X running. The final assembly line as a minimun could go 2x capacity by simply adding a 2nd shift. Sub-assembly supply lines are easier to duplicate, and generally take less time than major components.I think they are still using ~100% of the 18650 capacity that is available to them. (Which is why they said that there is a backlog of S&X orders and they are filling them as fast as they can.)
Are you saying CT production capacity will be ~80k a year ?I think this is where they build the AWD CT (same powertrain) and eventually the Tri-motor CT (which will share powertrain with Plaid Model S expected for Summer 2020)
No, I'm saying Tesla could use the spare capacity on the S/X line to start AWD CT production VERY quickly (much sooner than "late 2021). The actual production numbers for the AWD variant would be something like (total S/X installed capacity) - (current S/X run rate). Then more capacity could be added with new lines (even by using more Sprung structures), then using the Model 3 infrastructure separately to add the RWD variant.Are you saying CT production capacity will be ~80k a year ?
I hope it will be more like 10k/wk.
I think they still need to figure out how to make stainless steel body in bulk.No, I'm saying Tesla could use the spare capacity on the S/X line to start AWD CT production VERY quickly (much sooner than "late 2021). The actual production numbers for the AWD variant would be something like (total S/X installed capacity) - (current S/X run rate). Then more capacity could be added with new lines (even by using more Sprung structures), then using the Model 3 infrastructure separately to add the RWD variant.
No paint, little body (just laser-etch, bend, and weld), maybe some hull coloring but I think even that'll wait for now and people can always use wraps until then.
Cheers!
The author says "as the vehicle speed increases, the coefficient of drag is actually going down, so this is some clever stuff." and "at 88 mph, it gets down to about 0.38 in reality, I suspect at high speeds this car is probably closer to 0.3"
I think there is little chance of Musk wanting to carry technical debt into a new product.Tesla will reuse existing powertrains, the 2 that exist now. First will be Model S/X for AWD; then next will be Model 3 for RWD as new capacity becomes available (when Shanghai and Berlin come online)
