SSonnentag
埃隆•馬斯克
Do we know for certain what size wheels and tires were/are on the CyberTruck? I've seen one guess that they "look" like 35x12.50's, but still nothing on the wheel size.
Read somewhere they are 35" tires.Do we know for certain what size wheels and tires were/are on the CyberTruck? I've seen one guess that they "look" like 35x12.50's, but still nothing on the wheel size.
Not loaded, pulling a trailer, or driving in stop and go traffic. The Cybertruck will use more electricity when loaded and/or pulling a trailer, but the difference in cost of energy will still be great.That worst case results in an even more unrealistically low average annual mileage.
Maybe if there’s an error, it’s in his assumption of 19 mpg for the F150. It gets as high as 25 mpg.
That's not the wheel size. 12.5" that SSonnentag guessed is probably correct. Also there will likely be a choice when it comes time to configure.Read somewhere they are 35" tires.
I guess there’s enough unknowns, it’s not worth pursuing any more.
That's only part of the wheel size, since it doesn't list rim diameter, and frankly 12.5 is more likely tire width but the rim is probably narrower than that.That's not the wheel size. 12.5" that SSonnentag guessed is probably correct.
How do they get 57" bed width with 78" overall width and 12.5" tire width?That's only part of the wheel size, since it doesn't list rim diameter, and frankly 12.5 is more likely tire width but the rim is probably narrower than that.
They're likely 20" wheels (wasn't thinking). What isn't known is the kWh capacity of the battery. If, as was implied during the reveal, the 500 miles was loaded, you'll need a 300-350 kWh battery. Double that if you're pulling a 14,000 lb trailer.How do they get 57" bed width with 78" overall width and 12.5" tire width?
I have a strong feeling Tesla's range and consumption numbers are based on much narrower LRR tires and a low drag wheel cover (which unlike the concept allows some airflow for brake cooling). No plastic wheel arch flares, either.
Those soft, wide tires and flares greatly enhance the looks, but shout 500 Wh/mile consumption to me....
Agree, I speculated similarly that the range number was with different tires.I have a strong feeling Tesla's range and consumption numbers are based on much narrower LRR tires and a low drag wheel cover (which unlike the concept allows some airflow for brake cooling). No plastic wheel arch flares, either.
That's what I heard during the reveal. It was quick so it was easy to miss, or maybe I misheard.Where/ how did they imply 500+ miles loaded? I'm leaning toward 200 kWh.
It was already posted in this thread that the tires are 35x12.5x17 as noted by Motortrend.
24 inch wheels are for posers and not something anyone would use with that small of a diameter tire. Maybe with 49" tires..
I completely agree with you, but there is no possible way those wheels are 17". The sidewalls would be much, much taller.
I think that the aero disk covers more tire than you think it does.
