What's your guess. Do the DC-DC need upgraded to 1000V output, or is it a software flag? (plus new nameplate).Nope. The actual charging cabinets are still V3, limited to ~500v and ~250kW per port.
well that's a colossal bummerNope. The actual charging cabinets are still V3, limited to ~500v and ~250kW per port.
If it was a software flag why wouldn't they have flipped that in Europe so that all of the 800v cars there could take advantage of it? (I get that it would be weird to provide faster charging to non-Teslas, but it would increase the throughput of the chargers.)What's your guess. Do the DC-DC need upgraded to 1000V output, or is it a software flag? (plus new nameplate).
Hum, good point on 'if can, why isn't it'.If it was a software flag why wouldn't they have flipped that in Europe so that all of the 800v cars there could take advantage of it? (I get that it would be weird to provide faster charging to non-Teslas, but it would increase the throughput of the chargers.)
I think new hardware will be required. (But it is weird that the DC bus connecting cabinets is at higher voltages, but I don't know how the internals are designed, maybe there is a 1000v capable DC-DC to connect the bus to the rest of the cabinet, and then smaller 500v capable DC-DCs for each individual port?)
Maybe. But such a change would come with a massive improvement to the charge curve at v3 chargers too. Made the assumption,as I made clear, of no changes to c-rate. If there are, then everything could be a lot better!It will help a lot if/when v4 finally goes 800V. A Tesla engineer on one of those CT YouTubes gave 10-80 time on 800V. I don't recall the exact number, but it was in line with Model 3 on v3. Tesla is in no hurry to deploy 800V chargers, though. Hopefully someone will charge a CT at an EA or EVGo charger and report back.
Did it stop there, or was that as far as he opened it?I will say that CT has the wrong door hinge on one of the doors, both should open up completely.
It stopped. He suspected they accidentally installed one of the front door hinges on the back right. Other reviews had both back doors open completely. His had a list of issues; a rattle in the back seat (due to the center armrest not locking in place), the steering wheel cannot be adjusted, and the door issue from his initial look. He has it for a week and is doing extensive testing.Did it stop there, or was that as far as he opened it?
So that means less than 200 miles as a practical matter with 75-85 mph speed limits. Wow! Range extender is pretty much mandatory.
Huh? As far as I recall their highway test is at 80 MPH, or is that their 15-minute charge challenge and the highway test is at 70 MPH?So that means less than 200 miles as a practical matter with 75-85 mph speed limits. Wow! Range extender is pretty much mandatory.
70 mph usually.Huh? As far as I recall their highway test is at 80 MPH, or is that their 15-minute charge challenge and the highway test is at 70 MPH?
But if you are worried about range you probably wouldn't be using off-road tires...
I added it to my Beast order earlier today. I assume if things change before delivery in 6+ months I get my $500 back.So that means less than 200 miles as a practical matter with 75-85 mph speed limits. Wow! Range extender is pretty much mandatory.
70 mph usually.
The configuration page (at the time of my screenshot) said the $500 is non-refundable...I added it to my Beast order earlier today. I assume if things change before delivery in 6+ months I get my $500 back.
They normally edit everything and put out a ~30 minute video on the test, that will likely have those details. It will probably be a coupe days, or maybe a week, as they have a lot of testing planned for the week.So about 488Wh/mi if it was 254 miles with 124kWh. At 46 degrees or whatever it was.
Wonder if they have any better shots of the screen and will publish later.
In their defense having manufacturers choose their own "adjustment factor" to get the range they want is ridiculous.Yep, just scanned through the video. They aimed for 70 MPH and it was 46 F outside while they were testing. People that think this represents a failure don't understand how the EPA rated range works.
EPA numbers are for comparison. No one should expect that they will be what a person actually gets. My comment was ~250 miles were achieved at 70 mph doing 100% to 0%. So if you're like me, on a trip you target 20% remaining at destination. 80-85 mph will use more energy, so I estimated that a normal range would be somewhat under 200 miles. Driving an X LR Plus at 75-80 mph gives a bit over 200 miles. A comfortable real world range in the Supercharger Desert would be 300-350 miles. Comfortable means if local power is out at any one Supercharger (and I've had it happen three times since 2020) there is enough range to skip. Of course, it's not the Supercharger's fault that the grid is down.Yep, just scanned through the video. They aimed for 70 MPH and it was 46 F outside while they were testing. People that think this represents a failure don't understand how the EPA rated range works.
