JRP3
Hyperactive Member
Isn't paint matching involved in most body work other than small dents that can be popped out? I've seen much worse damage repaired for a fraction of that cost.
Yah.Isn't paint matching involved in most body work other than small dents that can be popped out? I've seen much worse damage repaired for a fraction of that cost.
This is kind of blowing my mind. Shouldn't you be able to get an entire vehicle painted a factory color for less than $10K? If it's that hard to match and blend it seems as if painting the whole vehicle would make more sense and be cheaper.it's that getting back to factory spec paint using factory spec processes takes multi $10ks of labor.
Guys go back and watch the first 3 or 4 minutes of the video. The quarter panel and the tailgate were replaced. The quarter panel is the expensive piece here, because the quarter panel is almost the entire side of the truck. Not something that you can just unbolt and replace.
The other factor is that there is only one Rivian body shop in the entire state. They are going to charge top dollar for the work. I also agree with JRP3 if the paint is so hard to match, just paint the whole darn thing. Still 37 grand for a fender bender is mind boggling.
Clarification, I'm referencing the Red Rivian, it didn't have the quarter panel replaced and the bill was $42k. It also had ceramic coating which pumped up the price.This is kind of blowing my mind. Shouldn't you be able to get an entire vehicle painted a factory color for less than $10K? If it's that hard to match and blend it seems as if painting the whole vehicle would make more sense and be cheaper.
De-trimming a Rivian is a hell of a lot different than popping off some chrome trim with a spatula; to de-trim that whole unipanel so it’s prepared for a full paint job, the inner tub of the bed needed to be removed (you can see Munro do that in the video below), along with the rear window and the roof spoiler. And to get the roof spoiler out, you need to remove the headliner inside, and to get the headliner out you need to remove the windshield.
This is likely what happened but I was thinking that they could have supplied just the rear corner section. A decent body shop could have cut out the damaged part and blended in a new one. Heck I could have done that though it would take me a while.The quarter panel is the expensive piece here, because the quarter panel is almost the entire side of the truck.
I know it's not the same but 10 years ago I had my then 15 year old Land Rover repainted with "deluxe" urethane for $1500. Still looks great today.This is kind of blowing my mind. Shouldn't you be able to get an entire vehicle painted a factory color for less than $10K? If it's that hard to match and blend it seems as if painting the whole vehicle would make more sense and be cheaper.
I'm sure Cybertruck won't be cheap to repair but at least the stainless steel panels will be more robust to minor accidents.at least one body shop told me that Rivian does have procedures for sectioning parts from the unipanel so that you can, say, just replace the outer side of the bed up to the cab instead of having to do the entire thing
I don't think it's just Rivian. There are lots of similar stories about Tesla and other cars.They do have partial panel replacement available in some cases but these minor accidents and exorbitant repair costs definitely cross Rivian off my list.
It's not just a different charge port. It requires the ability to add the charger bypass contactors to the vehicle along with a way to control them, assuming the charge controller can handle 400V on its inputs. Otherwise, they also need to add charger AC side disconnects, or replace that unit with a HV tolerant one.Rivian should announce retrofits for any new purchase, problem solved.
CCS has separate pins for AC and DC, so the AC inputs can go to the charger, and the DC inputs bypass the charger. But NACS uses the same pins for AC and DC, and the vehicle must detect AC vs DC, then set the contactors in the appropriate configuration to route the power to the appropriate place.Doesn't the Rivian already have charger bypass for fast DC charging?
Rivian (RIVN) investors may want to mark June 20, 2023 on their calendars as the automaker will be removed from the Nasdaq-100 Index on that date. NASDAQ confirmed the removal on Tuesday morning, a little over a week after a JP Morgan Chase forecasted it would take place.
NASDAQ confirms Rivian (RIVN) will be removed from Nasdaq-100 Index on June 20, 2023
Rivian (RIVN) investors may want to mark June 20, 2023 on their calendars as the automaker will be removed from the Nasdaq-100 Index on that date. NASDAQ confirmed the removal on Tuesday morning, a little […]driveteslacanada.ca
RIVN was up 8.93% today.
How much should it fall because index funds sell?
