I went to the installer artsci recommended; Jeff Wise Automotive Service. They are located at 1947 Greenspring Dr. in Timonium, MD. Their phone number is 410-252-8361. Per artsci's post, I dealt with Richard.
Richard made the install look easy. He had me pull the car onto the lift and place the car in Jack mode. He then carefully (using a light source to clearly see), positioned the pads of the lift under the car and raised it. Then he let the air out of each tire, wetted the tires where they hit the rim, and installed each AlloyGator. By letting the air out of the tires, he was able to push each AlloyGator in place by hand prior to lightly pounding them with a mallet to ensure they were completely seated. Afterwards, he reinflated each tire.
Richard had me glue the metal clips to each AlloyGator prior to him installing them. Total install time from when I drove the car onto the lift to when I left was 55 minutes. Cost was $100.
If anyone in the Baltimore/DC area is looking for an installer, I recommend contacting Richard. He was quick. He was professional (having done the install before). He was very careful not to damage the car, the tires or the rims. Do note that there is another shop on the same block called "Wiser" The correct shop to use is "Jeff Wise Automotive Service". The shop doesn't look like anything (there are several rusted vehicles from the 1960's sitting there), but as they say, you can't judge a book from its cover. Very true in this instance.
