Tholland
Plaid/Black&ebony/21in wheels/OD- 5/31/21
Oh I agree. O has seen this yet. Which leads me to believe it will be a software update.I don't think anyone has seen 322 on an AWD yet
Same here. With the 20ths. Have never actually went to 100 but with the app it predicts 308. Our dual Motor only goes to 300. And that happen after one of the updates. The jury is still out if this said 322 rated range is software or not. However we don’t really worry about it.2018 P3D+, recently swapped to 19" wheels. Showing 309 @ 100%.
Any news here anyone? We’re well past Jan 1st so there should be a lot of cars built in 2020 already.
Right now, we only have 668 miles and the 100% charging marker is at 310 miles.
Going in for service on the 21st for a few minor issues with paint, brake light opening and rear trunk adjustment and will ask about this. I understand it is a projection when I am charging and it may be based on how we are driving. We will see what happens with the updates. Thanks.Interesting. I had not heard of anyone actually showing a 100% charge on an AWD of over 310 rated miles (higher values only applied to Performance so far). For that "315" number, you mean in the app, that's what it "predicted" it would be? If so, it can be very inaccurate, especially if you're at something like 20-50% state of charge. It's just a simple extrapolation which can be subject to large amounts of rounding error.
So, do be a little careful with these extrapolations. You do need to be charged to about 90% for it to be accurate, and even then, there may be some inaccuracy.
I do wonder, however, whether part of this extra 1.7kWh unlock that seems to be showing up now (293rmi20*265Wh/rmi20, 299rmi19*260Wh/rmi19, 313rmi18*248Wh/rmi18, all equal to 77.6kWh, which is higher than 310rmi*245Wh/rmi = 75.95kWh) relative to prior Performance vehicles is just Tesla displaying all the available energy right away, rather than hiding the first couple kWh of lost capacity from view, as they seemed to do before.
For now, I would sit tight for the first update of 2020. I anticipate they're going to be doing some modifications of the constant on the AWD to have them show the 322 number (but yours may never see this due to initial battery capacity loss). I also could be totally wrong. It's worth noting again that the number displayed without knowledge of the constant is not that useful. So keep an eye on that constant.
I'm getting 290 as well on a AWD. I have a Sept 2019 build with a little over 3000 miles. I think it's based on avg Wh/mi, not some battery capacity. Can anyone confirm?Fudge you guys...
I'm getting 290...
You've got that backwards. It's based only on battery capacity and not avg Wh/mi.I'm getting 290 as well on a AWD. I have a Sept 2019 build with a little over 3000 miles. I think it's based on avg Wh/mi, not some battery capacity. Can anyone confirm?
Nice feature, my 12k-mile 2018 RWD shows only 306 available. That looks to be in the median here, though I'm annoyed to have never achieved better than a 315 estimated range.The most resent Tesla app will tell you what your current 100% estimate is if you go to the charging screen and pull the limit over to 100% now (don't lift your finger, the estimate shows while you are moving the line). I guess it might vary a mile or two from what it would actually estimate if you 100% charged, but my LR RWD 100% charges to 322 and if I pull it over that's what it also estimates.
Then why does it keep dropping? A few weeks ago, 80% was 248 miles, now it's 232. That can only be because it's estimating based on the actual energy usage. There's no way the battery capacity degraded that much. The car is only 3 months old and only has 3000 miles. 100% is only estimated to be 290. How?You've got that backwards. It's based only on battery capacity and not avg Wh/mi.
Here's the entire ownership from new. We have been getting some cold weather here. It's been hitting as low as the 40s for a day or two. Otherwise, it's sporadically 60s and 70s.Then why does it keep dropping? A few weeks ago, 80% was 248 miles, now it's 232. That can only be because it's estimating based on the actual energy usage. There's no way the battery capacity degraded that much. The car is only 3 months old and only has 3000 miles. 100% is only estimated to be 290. How?
was told it reflects an estimate based on driving efficiency as well as other conditions.
What percent do you charge to, and how many miles does it display from the battery at that percent? What was the window sticker number for rated miles?I just took my M3 with only 700 miles and just under a month of ownership into the service center for a few minor body/paint issues and asked about the lower range (315 max) showing at 100% and was told it reflects an estimate based on driving efficiency as well as other conditions. My BMW does the same. He said I am doing pretty well to get 315.
