Motors are designed to spec. There is always a tolerance on what is considered acceptable, performance is going to be no different. If a motor is put on a vehicle it has met the specifications and is rated to operate within it's designed limits.
Going on the assumption that the motors in all model 3 vehicles are the same design, I don't see any way that the RWD and AWD-P motors are "better" than the non-P AWD cars. Non-P cars are software limited, that is the only way that the power rating for the rear motor is the same on RWD and AWD-P. Having a common drive unit design/architecture across all variants makes the most sense from a cost perspective.
Model 3 is actually a rejected Model S that didn't come out of the oven fully baked. What kind of ridiculous question is this?Given the P3 and RWD 3 have the same rear output I have been wondering if the standard dual motor cars are getting rejects that didn't make the cut for RWD or P series 3. What do you think?
The RWD could go a LOT faster with a software upgrade. The wiring and circuitry is what wouldn’t be able to handle the massive output. So in the P version, almost all the components and wires are upgraded.
The RWD could go a LOT faster with a software upgrade. The wiring and circuitry is what wouldn’t be able to handle the massive output. So in the P version, almost all the components and wires are upgraded. Throw in the front motor and you got jaw dropping supercar speed.
If there is any major difference in performance than there is an engineering/production problem. Any mass production manufacturer should never have a process that results in wide variance of production pieces.
But how much power is being lost in those MOSFETS? The total drive unit efficiency is very high and probably only a very small amount of power is being lost in the switching transistors. Is there a teardown that shows the heatsink size for them, that would give you a good idea.Tell that to the SiC MOSFET supplier...
For reference a ROHM SCT3030AL N-Channel SiC MOSFET has a 25 C on resistance of 30 mOhm nominal 39 mOhm max, a 30% variation. That means 30% more heat generation at the same current level.
ST SCTH90N65G2V-7, is 18 nominal and 26 max, a 44% range.
I think that is untrue, and frankly ridiculous. If you think that is the case you need to provide evidence to back up such an assertion. WIthout evidence, your post is nonsense.
Imagine...
You have a 30w speaker (motor) connected by thin, but good enough, speaker wire to a 1000w amplifier (traction battery) that stays within the power range of the 30w speaker so it doesn’t blow (software limited). No issues. Runs as expected.
Now imagine swapping out the 30 W speaker with a 2000w speaker and not upgrading the thin wiring and connectors. Add a second 1000w amplifier (front motor). Crank it up to 2000w and watch the wiring catch fire and damage anything it's touching.
Electronics common sense. The RWD traction battery uses the same 2170 lithium-ion batteries as the P. Components are upgraded from the battery pack all the way to the motor. Wiring is upgraded. Maybe some extra cooling features. I can guarantee our rear motors are the same except with beefed up connections and components.
But Tesla isn't doing that. The rear motor in both the RWD and Performance models are rated at 211kW. They haven't upgraded anything, except maybe software.
The wiring for the front motor is separate from the back motor, so that will be all new in the AWD and Performance version. (And again rated identically in those two models.)
Do you think people with AWD delivered already could upgrade to Performance with a simple software update? That’s a hard pill to swallow.
Now, that will only work if he made all the AWD models Performance to eliminate producing multiple variants, then software limited it in hopes of you asking for the upgrade later for tons more cash like he did with the Model S batteries.
I would not be surprised at all if it was all just a software lock to keep the AWD different from the P. That said, I can't imagine Tesla allowing for it without charging an arm and a leg.
