Tinted side windows is a bad idea from a safety standpoint. Pedestrians, cyclists and other drivers need to be able to see you, to confirm your intentions.
As long as my intentions is not to run them over it will not be a problem._____
People often factor into their actions whether they can see you in the car and know where you're looking. Particularly pedestrians and bicyclists. As a pedestrian, I'm reticent to walk in front of a car even if they're at a stop sign unless I can see their eyes. And while it's safe to assume the huge majority of the time the driver knows what they're doing, I'm seeking to avoid that one time they aren't.As long as my intentions is not to run them over it will not be a problem.
....And while it's safe to assume the huge majority of the time the driver knows what they're doing....
True but in that case you'd be looking at them through the windshield which won't be tinted. I run 35% side and 90% rear on my Roadster. Would go slightly lighter on the rear if I had it to do over again but that car is so low I get blinded by headlights behind me.People often factor into their actions whether they can see you in the car and know where you're looking. Particularly pedestrians and bicyclists. As a pedestrian, I'm reticent to walk in front of a car even if they're at a stop sign unless I can see their eyes. And while it's safe to assume the huge majority of the time the driver knows what they're doing, I'm seeking to avoid that one time they aren't.
Actually, the typical case is looking through their passenger window as they're typically pulled near or into the crosswalk. The main case being they're turning right on red and looking at traffic coming from the left and I'm on their right crossing on my green walk signal. Not infrequently they'll see an opening and not realize a pedestrian is coming from their other side.True but in that case you'd be looking at them through the windshield which won't be tinted.
With tinted windows, it's very hard for me to know if they've seen me or not.
Yep, happens a lot in downtown areas, but it looks something like the following. The driver has pulled into the crosswalk, typically trying to see to their left to see if it's clear to turn, and so the pedestrian is looking right through the passenger side window.Don't know the _exact_ details of your lights and driving - but i do know, after a few trips to the states that you can go right on red if not said else on a sign.
Remove it!Have to figure a grille option, current grill cheapens the look if the car.
This varies state by state. Allowed in California, but not in all other states....i do know, after a few trips to the states that you can go right on red if not said else on a sign...
