Answers to questions above:
This would be a perfect time to find out exactly what amp hour capacity the individual cells have. Pull some good ones out of the damaged module, fully charge them and then fully discharge them and measure the capacity. Unless there are markings on them already designating the capacity.
If you take a picture straight down on a left "pack" and right "pack" (since you say they are different) such that we can count the amount of cells, you can finally be able to help us solve the mystery of how many cells the Model S contains. If I'm not mistaken, there are 16 modules (or as you call them "packs") in the 85kWh pack. You show 14 in the flat section (1 damaged one taken out). There should also be two more stacked on top of each other near the front of the car.
- - - Updated - - -
Originally Posted by
dm33
I think (but am not sure), that Tesla manages the battery charge at a much lower level than half a pack. It will try to balance the cells to maintain proper change. Not sure if its down to individual cells or a relatively small group of cells.
Yes, it's a much smaller level. From looking at pictures of the battery diagnostic screens, Tesla manages it at 6 groups per module. Given 16 modules in total (for 85kWh pack) that's 96 groups of cells. One group would have all the cells wired in parallel so that they self balance (however each group must be balanced individually).
Battery modules – all 16 of them – are divided into 6 sections and voltage is individually monitored on each of them. It is passive monitoring. Each section connects 74 cells in parallel, then all 6 sections are connected in series to complete one module. Battery does not have self-balancing capability, charging or discharging is being done at the same time with the same current on all battery modules / sections in whole battery pack. Smallest group of cells that can be charged / discharged is one module.
Tesla designed battery modules that are connected in mixed parallel and serial configurations for few simple reasons:
- small cells could not be connected all in series due to size and electrical properties. (if all connected in series voltage would be about 25.500 Volts)
- if few cells will deteriorate, whole battery pack will still be usable unless voltage difference between sections will be to great (then system will shut down battery pack).
- manufacturing is easier in that configuration as each cell is connected with hair thin short wire, then sections are connected with metal plates all at once.
Final charge is done once all modules are assembled all together into battery case. Once installed in battery pack, battery is charged during final charge using constant current method.
Martin
