how do you MISS a supercharger?But what happens if you miss your supercharger? It's not like you can just make a u turn at the next light.
you don't get a prize for arriving at a SpC with extra miles, trust your trip planner and try to arrive with a low SOC, of course weather conditions and severe elevation changes need to be factored in but the scenario you've offered is a poor strategy.See here it is.... run the car down to less than 10% if that.... and then the 'quick out' is leaving with what?? 50-60%?
so essentially... you run down to a bare minimum .. no real room left for an error... and then to get out quick... you only charge just up to... enough to.. repeat the process again at the next stop.....
Is that what you're used to driving an ICE?? You're in an unknown area.. and you purposely run the tank down to 2 gallons... and hope you can find the 'cheap gas' on the road ahead... but you're only going to get about a half tank... cause you wanna split fast....
gotta build a lot more chargers before I feel " real comfortable " with that...I gotta sit till I get at least 80% and I'm not running down to less than 25%... essentially.. a 1/4 tank to 3/4qtrs...
pushing a Tesla is NOT recommended.. (fingerprints!!)
why not? you don't win a prize for arriving with any extra miles and the lower the SOC the faster the initial rates of charge will be.If 20 miles from next SC and I have, say 40 miles of range is it worth speeding up to arrive "more empty" and thus charge faster and, overall, save more time? Speeding-tickets aside, of course ...
Generally not too much.
The superchargers are generally well located but not always where I would ideally want them to be.
My wife actually loves that we are forced to stop because "the car has needs." Before we got the Tesla, I would want to drive straight through without stopping, and be impatient to get back on the road if we were delayed even by 5 minutes for a bathroom break. Now the car's needs dictate that we stop every couple of hours, and I've discovered that break is a good thing for me. It breaks up a trip into shorter segments which have a supercharger as a mini-destination, rather than one long segment which takes all day.The annoying part is that at this point in time the Supercharging network pretty much dictates the route and the stops and the minimum duration at each stop. You are forced to follow the car's needs.
Like Inyokern, for instance?
This is an inaccurate interpretation of how pairing works. There are plenty of resources here at TMC which should alleviate your unnecessary stress regarding pairing at Superchargers. In most cases, a "trickle" is absolutely not realistic.
I have seen the video. I've also Supercharged over 25k miles on road trips. And I've been reading and participating in this forum for quite a while.well..I've seen the video..have you?? The 1st Tesla gets 100+ KW..and the second gets about 35KW if that... so it is less than half...
A question for you: have you searched this forum (as I suggested) to understand exactly how it works in conjunction with tapering? The real-world scenario is that two cars don't show up simultaneously with a near-empty state of charge, and drive straight up to paired Supercharging stalls. More likely, there are a couple of openings and someone's already tapering. As I mentioned in the post you quoted, it's an inaccurate representation of real life.
You're making this argument while stating that you've never been to a supercharger.well..I've seen the video..have you?? The 1st Tesla gets 100+ KW..and the second gets about 35KW if that... so it is less than half...
I believe he states that each pair can only pull 90% of the total of the maximum 150KW...
that means aprox. 135KW is actually available on any pair of chargers...If the 1st car is pulling 105KW... the second can only pull about 30-35KW tops... and it will usually be far less till that 1st vehicle disconnects... so is 1/3rd a 'trickle' compared to 3 X's that??/
I guess that depends on whether you're the one getting 105KW... or the one getting 35KW...
I have been paired, and have gotten the 35kw (or whatever tiny number it was) when I just pulled in with someone who must have arrived on fumes (electrons?). Soon therafter, my KW rate started to go up and up and up. I'm sure it added a little time (single digit minutes), but not 3x the time as you're implying.
Super chargers planned for
South to north on 101 are
Eureka Ca
Crescent City Ca
Bandon-Coos Bay Area
Newport-Lincoln City area
Seaside Or open in next 10 days
Aberdeen Wa
Forks Wa or Port Angeles Wa
