The charger can certainly throttle the charging rate as well.Also, the throttling would be from the vehicle, not the charger.
Not inherently. Chargers can have power design limitations independent of their current limitations. For example, you are unlikely to be able to pull 450 kW out of a “350 kW” charger at 500A and 900V.Everything you said is, well, wrong.
You could pull more than 150 kW on "150 kW chargers" because they are limited by the current and not the rated power.
That’s my initial guess as well in this case but it certainly could be from the charger.Also, the throttling would be from the vehicle, not the charger.
None of this was my own words, I was just repeating what was said in the video, right or wrong... He did say that he hated ABB chargers, and preferred the Signet ones, but he said in his area, ABB was usually what they had.Everything you said is, well, wrong.
The names "150 kW chargers" and "350 kW chargers" are misnomers.
Yes.anyone try Korean CCS adapter with S/X yet? (refresh)
Yes, and since the battery packs are higher voltage (at least the Plaid) and the stations are current limited, you get proportionally higher charging power. 110S vs 96S if memory serves me. That's 14.5% more power at the same current.anyone try Korean CCS adapter with S/X yet? (refresh)
OK, I'm a dope. Looked back in this thread for a web page in order to order the CSS1 from Korea. Can't locate it. If you have it handy please let me know what it is.Today is 3 business days from Tesla order date. They should have it soon I would bet.
I did. I charged for a couple minutes at an EA station at 117kW, about 60% SOC. I haven't tried this car at a Supercharger yet, but from my experience with a couple other Teslas, that's power was probably the most the car would take at that SOC.anyone try Korean CCS adapter with S/X yet? (refresh)
Thanks,
Rich
How is the car pulling 538A through the CCS adapter from the charger if the CCS spec is limited to 500A on the connector?
Can you share a link to the spec?
H.11 REFERENCE NOTES FROM UL 2251 H.11.1 NOTE 1 – Clause 45.3 – Repeated here for reference: “The temperature measurement shall be made on the wiring terminals and at the contacts of the equipment, if they are accessible for mounting thermocouples. If the equipment has no wiring terminals or they or the contacts are inaccessible, temperatures shall be measured as close as possible to the face of the equipment on the male contacts inserted in the mating device. “
H.11.2 NOTE 2 – Clause 45.5 – Repeated here for refercence: “For devices rated less than 200 A, the load shall be applied continuously. For plugs, vehicle connectors, or breakaway couplings rated 200 A or greater, the load shall be applied for 20 minutes followed by a no-load period of 10 minutes. This cycle (20 minutes load, 10 minutes no-load) shall be repeated until temperatures stabilize. The plug, vehicle connector, or breakaway coupling shall be coupled to mating device that employs the same AWG size power conductors that are utilized in the plug, vehicle connector, or breakaway coupling. For receptacles and vehicle inlets rated 200 A or greater, the load shall be applied for a single 20 minute period, with the AWG size of the power conductors sized as normally employed in the receptacle or vehicle inlet.”
So it sort of sounds, at least from the J1772 spec that you should design for at least 400 amps continuous, but that for non-continuous use like the adapter in a car or the cable on a charge pedestal are likely to see, you can kind of go nuts as long as it meets the temperature rise limits. There's another couple ISO specs (IIRC? if somebody wants to track them down, let me know and I'll dig up the spec numbers again) that control CCS that I haven't bought, because while I was willing to spend $85 on specs I'll never need in practice, I wasn't quite willing to spend $1200 on them (these other specs are for some reason vastly more expensive).The EVSE may now energize the system by closing the main power contactor and charging may commence at power levels up to the rated maximum continuous current of the EVSE for continuous rated conditions, or up to the rating of the protective circuit breaker for non-continuous conditions, or up to the maximum rated current of the EVSE for DC charging as provided by the digital data link. A continuous load is defined as operating at a given level for more than 3 hours.
Thanks! Emailed them.![]()
Get your Tesla's CCS1 Adapter From Korea!
Nothing beats the convenience of being able to charge your car with a Tesla Supercharger. But there are times when you need to use a non-Tesla charger, and having an adaptor can make things much easier. So, it's excellent news for all Tesla car owners everywhere when the carmaker decided to...www.harum.io
The J1772 spec you listed is completely different: Its for the J1772 connector.J1772_201710: SAE Electric Vehicle and Plug in Hybrid Electric Vehicle Conductive Charge Coupler - SAE International
This SAE Standard covers the general physical, electrical, functional and performance requirements to facilitate conductive charging of EV/PHEV vehicles in North America. This document defines a common EV/PHEV and supply equipment vehicle conductive charging method including operational requirementswww.sae.org
The SAE J1772 spec has this to say about the DC pins for SAE Combo:
Appendix E, Startup Sequence, Section i:
Wait so you're saying instead of just using the J1772 connector for AC and DC charging, they added two more big connector ports instead to support DC charging? No wonder CCS is a disaster.The J1772 spec you listed is completely different: Its for the J1772 connector.
It's possible to DC charge via the J1772 connector as per spec (not to be confused with the CCS connector, which is controlled by the IEC spec I linked above)
However, no commercial vehicles (or charging stations) implemented DCFC via the J1772 connector. See Weber Auto's excellent video about it:
The J1772 spec's most current revision includes coverage for the two additional pins for DCFC, and some of their communications, flowing IEC-62196 down into the J1772 spec. You'll note that the numbers I cited were from the section of the J1772 spec covering "DCFC Level 2" which is the one using the IEC-62196-3 spec:The J1772 spec you listed is completely different: Its for the J1772 connector.
Ok so I watched the video and you can only support DC charging up to 48 kW using the J1772 connector. I feel better now lol.Wait so you're saying instead of just using the J1772 connector for AC and DC charging, they added two more big connector ports instead to support DC charging? No wonder CCS is a disaster.
The mistake they made was not using the same pins for DC and split phase AC. Anything that can carry 350-400A DC can carry 80A AC. There is no need to have separate DC and AC pins. Roll the 2 AC pins and 2 DC pins into one and you essentially have the Tesla connector. Of course, this connector can't do 3 phase but neither can J1772. Ideally, they should make a connector with 2 large shared pins for DC+/DC- in DCFC mode and neutral/L1 in split phase and 3 phase AC mode and 2 smaller pins for L2 and L3 used in AC mode only.Ok so I watched the video and you can only support DC charging up to 48 kW using the J1772 connector. I feel better now lol.
The J1772 AC Level 3 mode using single phase power would have provided up to 96 kW at a nominal voltage of 240 V AC and a maximum current of 400 A. This power level is closer to what J3068 implemented a decade later at up to 600 VAC, although J3068 version 1 only supports up to 250 amps.
