CaptUAL
I copied all from the A2Z EV Shop YouTube of the CCS1 Thunderstorm Plug (8/6/22):Not according to what someone posted upthread (bold emphasis mine):
@CaptUAL where did you copy those specs from and at what time?
I dug up your own post from not that long ago, it says 200A also:
Retrofit CCS compatibility onto earlier (NA) Model 3 - DIY approach
just received my gen 4 ecu and bundle of wires with board from 2muchsun 😊 Well my bundle looked nothing like that and I ordered July 5th, now going back to the listing shows this updated version (and it's cheaper).teslamotorsclub.com
Did the specs get edited at some point? Seems kind of iffy to bump it up by 100A like that. These specs perhaps need to specify how many minutes it can withstand at those currents.
The internet archive unfortunately did not have their product page cached so I can't tell when they edited it.
Actually that is the core issue. Because it's a passive adapter, Tesla has no way to tell what kind of adapter is attached (it can only assume the OEM one is attached). The adapter itself also has no way to specify a lower current limit to either the car or the charger (this is unlike the Mobile connector which does have a method to tell the car how many amps is the limit depending on what adapter is connected).
WWW.A2ZEVSHOP.COM A2Z EV is the first company to release an aftermarket CCS1 combo adapter for North American and South Korean Tesla vehicles. You can now charge your vehicle at any fast charging station. Road trip have never been easier A 2022 Tesla Model 3 RWD/SR+ we tested made a 10% to 80% charge in under 25 minutes. We carefully designed our product to ensure it fits perfectly your vehicle and without any danger to any of its components. Our adapter reproduces all the features of the original adapter. We equipped the A2Z Thunderstorm Plug with a dual temp kill switch that activates itself if the CCS1 combo adapter ever overheats, when your adapter's temperature reaches 90 °C the kill switch is triggered and stops charging your vehicle in order to protect it. When temperatures drops back to normal, your vehicle goes back to charging. Our CCS1 combo adapter has an anti-theft lock that prevents your adapter from being stolen or unplugged, only way to remove it is by authorizing it from your car or phone. Specifications : Power : rated for up to 150kW. Rated Current : 200A~150A Conductor Material : Titanium Copper Alloy Shell Material : Polyoxymethylene (Insulator inflammability UL94 VO) Operating Temperature: -30°C to 50°C. Storage Temperature : -30°C to 85°C Rated Voltage: 500~1000V. Security : Dual Temp. kill switch. Charging stops when adapter reaches 90ºC. Sealing gasket: silicon rubber Security : Anti-Theft Lock. Certification: CE, TUV, RoHS, ETL (in the process) Degree of protection : IP55 (Protection from dirt, dust, oil, and other non-corrosive material. Complete protection from contact with enclosed equipment. Protection from water, up to water projected by a nozzle against enclosure from any direction.
