As I mentioned in the "hacking" thread, we have logged the Chademo charging CAN bus
(while charging a LEAF) and apparently understood the Quick Charge (QC) "mating dance"
well enough to construct a Mini-QC charger, of appromimately 10 kW.
We have also logged the pseudo-CAN (Pilot Line) while Supercharging,
to better understand the SpC charging process. It has been suggested
in the hacking thread that the SpC CAN messages appear in the CAN3
data stream, perhaps sent by the on-board AC 10 kW Charger to/from
the Battery Management Module. The Pilot line is single sided, not
a CAN pair, and runs at 33.3 kHz instead of the CAN3's 500 kHz.
Presumably the Master Charger just makes that Pilot/CAN3 translation,
since it already has both the Pilot and the CAN3 I/O ports, but does
not actually participate in the SpC control logic.
Without any formal documentation, we have had to guess at the
meaning of some/much of the SpC data, but we do see the VIN
go from the car to the SpC. It appears that the car might specify
a maximum current, which tapers off after the battery is about
one third full. Apparently the SpC is free to deliver less than
that "max" current, to implement two-stall (A/B) SpC sharing.
With the QC process, it appears that the car (after the mating ritual)
requests a specific charging current, which the QC is expected to
follow, within some fairly narrow limits. To quit charging normally,
the car requests zero current.
We can share findings, and our guesses, if you are interested, or we
can try to check your discoveries against ours, if you prefer.
We are interested in expanding the group's knowledge through
responsible investigators.
More Later ... Tomorrow AM our EV Gathering group gets to see ...
a real live Model X.
Cheers, Gary
