Blunty, insideEV is wrong as confirmed by Tesla.
View attachment 65478Ran into this pic which was posted on plug share. Looks like someone already has one. This is from a chademo charger in Gastonia, nc
Sylvain Juteau, founder of the Quebec EV site roulezelectrique, is reporting that the adapter will be on sale in North America next month (January 2015).
http://roulezelectrique.com/exclusif-adaptateur-chademo-pour-tesla-commercialise-en-janvier-2015/
Cliffs: A direct response from Jérôme Guillen at the Montreal Store's grand opening: "I'm sure it will be January and you can quote me on it."
Difficult to tell from the pic, but does the adapter rest against the car, or is the weight of the charging cable enough to hold it back? Wouldn't want that giant-ass connector rubbing against my paint.
Hi, Mayhemm, if you plug the CHAdeMO adapter roughly, then the charger cable might hit your paint, but if you are careful connecting the cable first to the adapter away from the car, and then connect the adapter to the car, you'll never hit the paint. I've used the adapter a few dozen times but it never happened.Difficult to tell from the pic, but does the adapter rest against the car, or is the weight of the charging cable enough to hold it back? Wouldn't want that giant-ass connector rubbing against my paint.
Compatibility is more of an issue I guess. Last week I encountered a new-looking Nissan charger and tried five times, disconnected with errors, and charged only 10kWh. On the next day I got one error with 0kWh, then I was able to charge full 30 minutes. The charger is configured to stop after 30 minutes. I then topped up several more minutes. They charged me for only "one charge".
... it seems like its might be applying some meaningful torque to the charging port.
Unfortunately no. Approximately one out of four chargers has not been compatible with Tesla Model S. In addition, some chargers work, but derated to 107A (should be 125A if 50kW). I'm trying to share these info with Japanese owners and Tesla.Have you eventually succeeded to charge with all chademos?
I think it's the other way around.I think it is 107A because of the limitation of the battery in regards to voltage ( I think it is 375v). 44kW will probably be the highest you will get from CHAdeMO with the Tesla.
125Ax400volt = 50kW
107Ax400volt = 43kW so this is very good
Charging happens at somewhere around 340V when the battery is empty and goes up to 380V.
340V * 125A = 42.5kW
The current (125A) will be the limit due to the "low" voltage.
Even "limited" it would still provide around three times the charge rate of the most powerful level 2 EVSEs.
I'd take it in a heartbeat; even put up with that freakshow of an adapter.
