Do you know what you're looking at? Tell me what the car is doing from ~1500 seconds to ~1700 seconds. 3 minutes of what?
Out of a 30 minute test, the test cycle has only 3 minutes at highway speeds.
10% of the time you are at 75mph. That is about right for California. It's not legal, but it's correct.
Are you sure you really want a Tesla? Sounds like you should buy a Bolt.That is an assumption. My daughter goes to UCSB and the 101 in that area can suck more than a Dyson. It took us 1 hr to go 20 miles.
If the 101 was hosed, the Bolt would actually have done even better.
EDIT - GM purposely selected a distance that was the EPA distance. Gutsy move.
The point is, with a distinctively NON-aerodynamic (drag coefficient >.3), highway speeds will absolutely trash the Bolt's range.10% of the time you are at 75mph. That is about right for California. It's not legal, but it's correct.
My impression of the test is that it might be a better representation of "real world" fuel economy for turbo ICE cars, since the NEDC rarely forced the turbo on. EVs do not have that issue of being very fuel economy sensitive to the throttle so I don't think the switch from NEDC matters much. The test is still at low average speed and in no way representational of steady state driving at 70+ mph.Worldwide Harmonized Light-Duty Vehicles Test Procedure looks similar to the EPA 5 cycle test. Both of them are certainly tougher than the NEDC, which is kinda useless. A good sign the Bolt does well on the harmonized test. GM has certainly made an efficient car with the Bolt.
Yup -- the "real world" highway range, anyway.The point is, with a distinctively NON-aerodynamic (drag coefficient >.3), highway speeds will absolutely trash the Bolt's range.
Perhaps true for commuters, but it is obvious that the Bolt will cover commuting just fine outside of corner cases. Just do not confuse this test result with implying long trip driving suitability -- Wider Los Angeles or otherwise.10% of the time you are at 75mph. That is about right for California. It's not legal, but it's correct.
All EV makers currently (har) rely heavily on government handouts, in nearly all countries, not just the USA.
It's why some people have the mistaken illusion that an EV drivetrain is just as cheap as ICE. It's not close yet.
Ummm, no. When commuting off-peak hrs, I'm driving 70mph over 15 minutes of my 25minute commute. 10% is not a good metric to measure highway miles consumption.
Edit: that's not to say the bolt won't work as a commuter, only that YMMV really applies here.
When most people think of highway driving, they are thinking of running some distance at a constant, high speed. Commuters on urban and many suburban freeways don't see those kinds of speeds, but that is the driving profile on most road trips.
This is nonsense.This is where the comedy about "poor aero" killing off the next gen of EVs occurs. All EVs regardless of CdA are affected approximately the same. You don't get to defy physics because a wind tunnel told you a number.
@McRat Your mathematical skills are poor. Drive train and rolling ristant may be linear, but reduction by air resistance is not. It goes up by (at least) the square of speed. So lower CdA makes a larger difference at larger speeds.
Bolts are good for local driving. Choose according to petsonal priorities.
This is nonsense.
In SI units, result in newtons:
Rolling resistance is tyre_RR * mass * G
Air resistance is 0.5 * Rho * CdA * velocity * velocity
A low Cd vehicle at highway speeds over 65 mph stands out from the crowd
Read againYou are confusing numerical gains with percentage gains.
It's not CdA². It's velocity². Velocity changes square the power required, not the CdA value.
Wrong again.To clarify, increasing your velocity is a geometrically increasing progression..
