TonyWilliams
The Kia Soul EV and Hyundai Ioniq have a stated nominal pack voltage of 360v.
What would the nominal voltage have to do with the debate? The max voltage is still 400v, plus or minus 5v.
There are 96 cells in series at a maximum of 4.2v per cell. Loads of other cars, including "large battery" Tesla cars share this configuration.
The 69-70 kW charge rate I've seen photos or videos of for the Soul EV and Ioniq reached that rate at around 66-76% state of charge so the charging voltage was likely around 390-400v which make the current be around 175-180a.
I doubt that VERY seriously. Not even a Tesla 100D is banging out 175-180a at 400v !!!
The peak current is likely reached at very low state of charge. One video shows the Ioniq starting a charge at 10% and quickly ramps up to about 62 kW which probably implies around 190-200a and then the power very slowly rises with increasing state of charge and charging voltage as the current slowly falls.
It's absolutely at 200 amps, therefore:
62kW / 200a = 310 volts (yep, that about right for 10% on a 96s pack)
70kW / 200a = 350 volts
72kW / 200a = 360 volts (I doubt the Ioniq charges faster than this)
Again, it's easy to guess the voltage when we already know that it is 96 cells in series... just like a Tesla.
All evidence I've seen and heard points to a peak current of around 150a for the Bolt EV.
There's zero evidence of that. There's circumstantial statements, like the reference to "80kW" in the owner's manual. I suspect that this is the charger placard for some mythical 200a * 400v charger that doesn't currently exist.
I fully expect the future Bolt to charge at 200a, just as I am sure that it is restricted to 125 amps today. We can easily prove this to end the debate, and we will.
Seems reasonable but I would guess 90-95 kW for an actual 55 kWh pack. Of course, it would tend to be higher if it has a larger capacity that is limited by software until an owner pays for an over-the-air update to access the full actual capacity as in today's 75 kWh S60.
It would kill any car company to sell millions of cars with an extra thousands of dollars worth of unpaid for hardware in the hope that somebody might actually pay for it later. Plus, those same battery cells will likely be cheaper in the future. I don't think this is wise, and a completely different concept in a $100,000 car.
If it's like the S and X then the Model 3's smallest pack may have a smaller nominal pack design voltage thus a 55 kWh Model 3 might be similar in voltage to an S60.
Pure speculation, but sure, it's possible.
