The BMW/VW/Chargepoint plan to install a bunch of CCS stations on the coasts may be enough to trigger critical mass.
BMW VW team up with Chargepoint to create high speed EV charging network
What is the number 1 challenge for high volume sales of BEVs?
It's not actually cost, because multiple manufacturers see cost reductions coming.
It's not range, because multiple manufacturers see range increases coming.
The number 1 challenge is
charging.
There's the barrier of ubiquitous home charging, but that will be overcome by market demand and government support.
The problem is that you need fast charging to make ownership practical, unless you want BEVs limited to 2nd vehicles. Fast charging isn't just about how fast the vehicle itself charges, but also about access to fast charging. Access to fast charging isn't just about there being a fast charger en route, it's also about the fast charger being available for use when you get there.
If you want charging to be practical for long-distance travel, you want it to be as fast as possible to avoid adding too much time to trips.
If you want chargers to be available for use, you want charging to be as fast as possible to avoid contention.
If you want chargers to be available for use, you want to simplify the system as much as possible to maximize uptime.
If you believe that BEVs can and will be long-distance vehicles, installation of individual 62.5kW DC chargers with high operational overheads are not doing anything to help.
