I'm just back from another road trip from SF to LA.The question is... most people were driving 75+mph on I-95 this past weekend, with cruise control set to 79 mph for many miles on end. What kind of range do you have in that situation? And we already know the situation after driving 2-3 hours... the Bolt charges slow, mostly under 50 kW if you can find a free plug. It just isn't the kind of vehicle that brings about the EV transition as it should given this limitation.
Here are some real-world numbers. On the way back, I stayed overnight in Bakersfield and put a full charge on the car. I then drove back on CA-99 with an hour and 15 minute or so layover in Atwater to recharge the Bolt during lunch. Total trip time was around 6 hours from Bakersfield for ~290 miles today. Google estimates a non-stop trip time of 4.5 hours.
During the first segment back I reset the trip odometer, efficiency calculator, and average speed calculator in the car while on the freeway and recorded a ~100 mile stretch on flat Central Valley highway at 90-95F, tires underinflated by ~2 PSI (36 PSI cold, 40 PSI hot), the A/C set to automatic mode at 73F target temperature, cruise control set to 76 mph, and apparently calm conditions with little to no wind.
Over that stretch my average speed was calculated at about 74 mph due to rare and temporary mild congestion slowdowns. My average efficiency was 3.4 miles per kWh from the battery or about 300 Wh per mile. That's consistent with a range of around 190-200 miles with 58-59 kWh of available energy.
My starting battery range estimate was a bit over 200 miles from previous driving the night before at a similar speed. I drove around 166 miles to Atwater and arrived with about 33 miles of range remaining.
