The CCS connector is rated for 350A for a long continuous time/period.
But does it need to?
400kW sounds impressive but again that is at 1000V and 400A. So in real world use with the voltage of today's packs it won't be much faster than what Tesla is currently doing (I forgot the exact numbers, but with the 120kW it's over 350A).And here we go! Up to 400A!
ChargePoint Express Plus Debuts: Offers Industry High 400 kW DC Fast Charging
Probably to charge bigger packs rapidly or new chemistry which can sustain it longerBut does it need to?
Using some relais you can reconfigure a pack on the fly I think400kW sounds impressive but again that is at 1000V and 400A. So in real world use with the voltage of today's packs it won't be much faster than what Tesla is currently doing (I forgot the exact numbers, but with the 120kW it's over 350A).
So it looks like all the 350-400kW next gen standards are depending on high voltage (800V-1000V). This has the advantage of using similar size conductors (insulation aside), but the problem is backwards compatibility with older 500V chargers, unless the pack can be reconfigured to half voltage on the fly.
I highly doubt that. The Tesla connector can handle 365A for a short period before it needs to cool down. Luckily the battery can't handle the high current either so throttling starts.
The CCS connector is rated for 350A for a long continuous time/period. That's a big difference between Tesla's connector and CCS. One is peak current, other one is continuous.
Additionally, we already know that Tesla has a liquid cooled supercharger/cable design, so longer sustained usage at those current levels may be quite possible.
I doubt they lost the design documents, so I assume they still have them.You mean they had a liquid cooled Supercharge cable design.
(Actually they had one in public testing but have since removed it, so we have no idea if they have anything else in the works, but we can assume that what they were testing didn't work out long term.)
Pretty cool... I hope that:
3) They use the capability to host a 3rd type of charging cable as an opportunity to license Tesla's connector
ChargePoint might have a little more credibility if its AC charging stations offered more than 30A.
(responding to my own post)
I note the Specs Page says: "Universal Compatibility: Any EV with fast charging capabilities can be accommodated with up to three different connector types, configurable per station."
So if any EV fast-charge capable EV can be accommodated... that must include Teslas, right?
That would probably do it. I'd love to see a Tesla connector hanging from one of those however....Maybe via the ChaDeMo adapter?
And their DC (CCS) stations are 25kW instead of 50kW like most CCS/ChaDeMo DC stations out there.
Maybe they'll do the CCS to Tesla adapter!That would probably do it. I'd love to see a Tesla connector hanging from one of those however....
