aviators99
Model S - R140
So, I have no 3G coverage inside my garage. None. Nada. Zilch. This means that currently, the app is completely useless when my car is plugged in at home. And of course, Tesla won't hand out the car's phone number, so I can't put it into my AT&T repeater so that the car gets a signal.
Does anyone know if the app will support use of Wi-fi when it's enabled? Otherwise, all these neat features (checking/initiating charge, climate control, etc.) are completely useless when the car's at home :crying:
If and when WiFi is enabled, the car will be on the Internet via WiFi. The biggest difference between when it is using 3G and when it is using WiFi is that the external IP address will be NATed via your WiFi router (or tethered smart phone). This is likely the reason for the delay in rolling out WiFi. With 3G, the car does not have to maintain a continuous connection with Tesla in order for the app and updates to work. It has an external IP address for Tesla and the app server to reach. When you are NATed through a router, unless you open up ports in the router, Tesla and the app server will have no way to reach the car directly, so the car will need to maintain an open connection through which it can communicate bidirectionally. That's a real hassle, and much different from what the car is able to do now (and will even use more battery in the car!). The alternative, as I mentioned, would be to instruct the owner to open up ports on the WiFi router, but that's a bit complicated for the masses. In terms of normal Internet functionality outside of updates, TM monitoring, and the app, there is no problem using WiFi via a NATed address. But I assume that they don't want to roll it out until they can use the connection for updates, monitoring, and the app.
