Y’all… 136 miles out of 340 is 40%. Adding 40% in 15 minutes is not indicative of a great charging curve or c-rate. Pretty much every other battery type Tesla offers adds 50% in 15 minutes. Heck, even my Model 3 RWD standard range adds 50% or 136 miles in 15 minutes, and it’s one of the slowest charging Tesla models.
When calculating gas savings, the Tesla website uses 42.9 kWh / 100 miles for the Cybertruck AWD, meaning that’s how much power it pulls from the wall to go 100 miles. Multiply by ~88.8% to account for charging losses (that’s the factor used for Model 3 on their website), and then by 340 rated miles, and we can guess that the Cybertruck AWD has a roughly 129.5 kWh battery. Multiply by 95.5% to get a usable capacity of 123.7 kWh. Multiply that by 40% and we can estimate that the Cybertruck added 49.5 kWh in 15 minutes, meaning average charging power was 198 kW. If peak is 250 kW, that means it might have already slowed down to around 146 kW after only 15 minutes, assuming a fairly linear drop. Ain’t no flat 250 kW charging curve happening here.
I believe Model S can add about the same kWh in 15 minutes as Cybertruck despite having a much smaller battery, which means the c-rate of the Cybertruck battery is disappointing. A bigger battery usually means you can add more kWh in the same amount of time, but not here.
800v architecture doesn’t mean a whole lot in terms of charging speed if your battery is limited by c-rate. Bjorn talks about that in detail in his latest rant on YouTube if anyone is interested.
