You don't think the read ultrasound sensors would cause it to stop before hitting the door? If not, why do you trust them to stop in any other context?
as mentioned, I'm worried because in all the Summon-out videos I've seen, the car first backs up a bit before stopping,
then activates the door. (btw why does it move
at all before opening the door??) I don't know how far the car will move before stopping and there's very few inches to spare inside my garage. That's the worry.
Are the ultrasonic sensors reliable enough at <8" distance
starting point? I don't know. Maybe they are, but if so why isn't a minimum bumper clearance setting of < 8"/20cm allowed in the Summon configuration?
To reverse-summon out of my garage with the door closed, due to my short garage the car would begin with the rear bumper
already closer than 8" to a large, sharp-edged hinge on the inside center of the door. This is with the front bumper practically touching the front wall of the garage.
It seems there's next to no margin of error if something goes wrong and the car backs up too much before opening the door, or if I manually abort and the car takes a fraction of a second to stop - unlike forward summon where you've got lots of time/distance to stop things. Note: here in Canada, Summon is
only available via the app and with continuous-press. No fob-summon here. So LTE/wifi data connection lag could possibly play into things?
The rear ultrasonic sensors are 21" off the ground, and they are L and R of the centerline of the garage door and car. So instead of aiming at areas of the door that are closest to the car (hinges, interior frame of the aluminum panel door), unfortunately the sensors are pointing at close range to a wide panel, the part of the door
farthest away from the car, about 3.5" farther away than that hinge. So it's possible the car could think its starting point is 11" away from the door when in fact it's actually <7.5" from the dangerous parts of the door. If I happen to one day park slightly farther back from the front wall, of course the starting gap is even less.
Maybe there's nothing to worry about if you just look at the math - any clearance >0" before stopping the car
should be fine. Maybe starting with <8" clearance, the car won't even budge before opening the door? I would love for this to work perfectly, but without knowing how Summon-out+Homelink works within this context, I'm not eager to risk it. Call me paranoid!
