They are good, their problem is they operate on Nazi style regiment, either their way or the highway!My offer was rather "tongue in cheek".
Tesla's customer service is worse than that offered by Morgan Motor Company.
Here is just one example:Wireless joypads shouldn't be a huge addition.. they already have bluetooth pairing for phones so it's just another class of device to add (probably already built into the bluetooth library they're using), and maybe a couple of extra buttons on the bluetooth screen to initiate pairing.
I'll be shocked if that support isn't rolled out within the next few months.
Agreed but that’s not quite the whole picture here. The parts are now becoming available, both the power-only and data-enables hubs are available to dealerships for retrofit (I got the engineer who did mine to check) but depending on what the ‘big Tesla computer in the sky’ says about your car, that determines whether or not you’ll get power only or data - even though the cars all have the required cabling in place and the OS is capable of utilising either or.You will find other car makers in a similar mess .. this is global supply issues thanks to Covid. You can choose to not accept the care and wait, but no-one knows for how long.
two charging pads on 2022 MYLRI agree, but where is the 6th port?
2 in centre console, 2 at the back, 1 in the glove box, and..?
Ranger can definitely do this - the one who came out to retrofit my hub showed me on his laptop.They could change the gateway configuration to specify whether the car has a data enabled USB hub or not. I’ve seen it noted somewhere else that there is a flag for this.
A ranger might be able to do it but if not I’d be surprised if the service centres don’t have a script to do it.
see
My car is back into Tesla in Feb for some window seals and rattles. I've added a request to the service for them to swap over the hub to a data-enabled one, and I've included part numbers. We'll see what happens. I won't hold my breath though.
its odd that it disables apps like games - you can still use the glovebox for a controller but I assume they consider that reserved for dashcam/sentry?
The manual does advise against using a usb hub, needed to enable a controller and usb stick to both be connected. Having said that, it works just fine for me.
So I think they are just covering their backsides, because yep you can use the glovebox usb port.
Given they describe themselves as a technology company and not a car company - they really do need to do compatibility testing, because currently it's like buying a new PC and being told not to use a usb hub with it.
Then they'd need a hub for the glovebox ports, but no chips to make oneI’d actually be ok with that, providing they gave at least one more data port in the glovebox or similar - sentry + music USB can be on one, and one for a wireless controller. Or as mentioned, build in bluetooth controller support and at that point I think I wouldn’t mind charge only front ports
To be fair, these are all increases in spec over what the people expected at time of order.Right now in the delivery thread there are lots of people that have deposits on £50k cars waiting arrival not knowing how big the battery will be, how far it’ll go, whether it has rear double glazing, what motor type/power etc.
This is more misinformation, as there is no Tesla data hub.Seems like this thread is filled with false info. If you buy the tesla data hub from tesla it will work with zero config!
There is also a third party model of the hub that offers data too that can be installed.
The only problem is that tesla will not retrofit the module!
