bonnie
I play a nice person on twitter.
Sorry. You don't know my background (or the background of others here) to dismiss those that disagree with you so casually by saying that those that have the proper background agree with you.
I think we should also update the number of miles driven as time goes on and amount of fires remains the same. Tesla tweeted just yesterday that over 100M miles have been driven. Overall I think this discussion can't really reach much usefulness in any conclusions before at least a year or far more fires happen. While playing with pure numbers might give you a certain % value it's going to be a theoretical number and the reality has to take into account uncertainties associated with every aspect of the measurement and estimation process. That comes from the very ground up including the uncertainties associated with raw data from the NHTSA etc as well as uncertainties related to the assumptions made. And nature only follows statistics properly when we have reasonable quantity of everything. Up until then we're doing a prediction game and have to live with the fact that 3-4 sigma fluctuations (that's 0.3 or 0.003% probability events) do happen on a regular basis because there are so many things happening in the world daily. Therefore getting a sterile number that points towards ~1% probability with just 3 events is not statistically fully viable even though the numbers work out to it because noone's done a proper assessment of uncertainties on input data and assessments (in a physics analysis doing the analysis takes ~5% of the total time, assessing the error and drawing the conclusions takes 95% of the time and effort).
Simple - this car represents a completely new design and the worry is that there are vulnerabilities outside the design/ testing parameters that will require an expensive recall or redesign. Because this is not an established automaker or drive technology it also puts a cloud on overall corporate health.
Stats are one way to get an early ID on potential issues, however I agree with those that a few events does not mean you have a problem, it only gives you a signal to investigate. There are a lot of other fields in which a few events will trigger an investigation (drug development for example) and others where a single event will completely stop use (aviation). Since there is no expectation of 0% fire rate for any motor vehicle and since in all three fires the drivers had time to safely walk away I doubt that there will be a recall unless a specific substantial design vulnerability is discovered.
my 2 cents anyways
. Boeing was grounded for several months for similar stats and similar problems. It is reasonable to think there is something that needs to be investigated.
Ummm, I'm pretty certain that the Boeing fires were not the result of impacts...IIRC those issues were the result of thermal runaway which has been fixed with a battery redesign. Calling them "similar" to the Tesla accidents is less than scientific.
that statement is so clearly off base and provocative that it seems intended to foment discord.
@BillHamp
I disagree with you. One thing is if the battery catches fire spontaneously. Then if the battery catches fire after having hit an obstacle is a completely different matter. Then also in the case of crashing it should be differentiated between crashing against road debris and collisions.
Actually we spoke about this matter before. I remember. It seemed like you agreed with me on this matter. I don't understand.
Bill, sorry, but you come across as totally suspect to me. I've gone through your forum posts. You show up and post after the first fire & with very few exceptions, your posts have all been about creating doubt as to the safety of Tesla's product.
What will you do after the NHTSA says 'no problem here'? Will you move on to ICE forums? Or have you already been on those forums talking about the lack of safety of gas engines and the danger of driving at high speeds with tanks of highly flammable liquid?
You've made your point repeatedly and keep bumping threads to keep them near the top. Sorry, I'm not buying that you're just a concerned citizen.
Johan said:Who is Bill Hamp and why did he register on TMC today and all of a sudden he's arguing this issue from any angle possible?
FluxCap said:Indeed my friend, indeed.
a lot of people have griped about pigs and moles and girls in dresses, but it seems most who have the proper background and studied the work agree the statement is reasonable and well supported by data.
Disagree with me about what? The comparison isn't between causes of fires, it is between the level of incidents required before someone concludes that an investigation needs to be done. That Li-ion batteries burn due to short circuit/thermal runaway is not up for debate. It is a fact.
Seriously??? It's obvious that Raffys point is that batteries don't simply ignite... they require an outside influence; If properly designed... as Teslas appear to be... they must be damaged or shorted to experience thermal runaway... as has occurred in EVERY fire.
Agreed.
These posts between me and FluxCap ended up in "snippines", written on his first day on this forum:
Seriously??? It's obvious that Raffys point is that batteries don't simply ignite... they require an outside influence; If properly designed... as Teslas appear to be... they must be damaged or shorted to experience thermal runaway... as has occurred in EVERY fire. That IC engines catch fire without any outside influence... just due to the inherent volatility of their fuel is not up for debate. It is a fact.
You are entitled to your opinion, but I would point out that as a moderator you ought to know the rules better than anyone and avoid setting a bad example. Using this forum to make personal attacks against a poster rather than addressing the topic itself would get anyone else a warning or a ban. After all, the rules say:
Be Courteous!
Don't attack others. Personal attacks on others will not be tolerated. Challenge others' points of view and opinions, but do so respectfully and thoughtfully ... without insult and personal attack. We also ask that you maintain a level of objectivity and be aware of your own biases. Don’t try to state opinions as fact and be careful to distinguish between the two.
I expect you will move your post and my response to the snippiness thread where both belong. Then this thread can return to a discussion of the fires.
The investigation has happened already, so I don't see the point of discussing "level of incidents required before someone concludes that an investigation needs to be done". I thought what is currently discussed is the statistics in comparison to ICE, not whether investigation is necessary.Disagree with me about what? The comparison isn't between causes of fires, it is between the level of incidents required before someone concludes that an investigation needs to be done. That Li-ion batteries burn due to short circuit/thermal runaway is not up for debate. It is a fact.
