dgatwood
Ummmm DC has a VERY high loss rate per foot which is why your cables are so thick. Want to rewire your house in 8 gauge wire? This is why we use AC.
That’s not really true. DC cables are usually thick because DC is typically used at higher current and lower voltage, and loss depends on amperage (current), not wattage (amps x volts).
We use AC because prior to about thirty years ago, it wasn’t practical to do large-scale, high-power buck/boost conversions to change DC from one voltage to another, whereas AC can be stepped up and down with only transformers. And when running a lot of power (wattage) over a long distance, higher voltage with lower current gives you much, much lower losses, but it isn’t practical to use higher voltages in your home, so voltage conversion is unavoidable.
But HVDC has lower losses than AC, at least when run over superconducting cables. So lately, a lot of distribution is DC, too, now that switched-mode conversion has gotten cheap enough.
