ℬête Noire
AKA how I long distance travel.This is ridiculous. It hits 126kW only from 44%-48% SoC, the rest of the plateau is very close to 120kW.
Now, if the Model 3 is capable of faster charging it will be only be at lower than 50% SoC. So you'll only get a significant benefit if you're very good at arriving at the charger at a very low SoC.
Charge until it tells me I'll arrive at the next SC with 12%-13% remaining, and go. You lose 2-3% right at the start, I assume a combo of initial acceleration + the supercan dealing with the last of the battery charging heat. Arrive at the next SC with about 8-11%, repeat. Never see below 90kW charge rate, nearly all of it 115kW and up, as long as you're on a well spaced route, don't run into a charging pair "share" situation, and your meal order is promptly served.
