I'm GUESSING that the study you're remembering actually said left foot braking doesn't help all that much because the driver's mental reaction time is far greater than the time to physically move the foot. That makes slightly more intuitive sense but I'd like to see the numbers.
The hill-hold situation is the obvious case where using both feet is useful. As are many situations when you're going slow with creep off and you need to make fine adjustments to the speed. Creep ON is kind of like having a bit of pressure on the accelerator; why is that OK when doing it manually isn't?
I do believe reaction time was factored in yes, but the time it takes to lift the right foot and then press the left foot was taken into account. Also, with two foot driving you lose potential leverage with your left foot normally on the dead pedal or other dead space which could help hold you in place when firmly pressing the brakes. It's also common, especially among older individuals who drive with left foot braking, to mix up the pedals... which obviously causes problems. Learning the proper right-foot-only technique is really the only way to avoid that.
We're not talking about on a race track where there is a need to be able to use the left foot for braking, I'm talking about normal driving on public roads.
As for creep, the Model S's creep setup actually doesn't work the way you may think it does, especially with the newer electronically actuated brakes. A minimal, if any, power is actually sent from the motor directly to the friction brakes. It's all a perception created by the electronics properly regulating power output. You're not actually holding the car back in creep mode like you would in an automatic ICE.
Plus the Model S does have hill hold, which works quite nicely. Although as a driver of many manual trans cars over the years, I personally never really need it.
Sure. But I'm talking about allowing just one or two kW of left pedal while the brake is engaged. Anything more accelerator pedal than that should give the warning and not increase motor power any further.
So you're saying applying 2kW of power to the wheels while applying some kW amount of friction, resulting in a net of X kW to the wheels is somehow better than just applying X kW to the wheels in the first place with no braking? This is counter intuitive, so I'm confused.
It happened to me as I drove it out of the parking lot after taking delivery
Was your mother slightly dragging the brakes during normal (not just very slow) driving? That's a common scenario. Of course, that's bad for the brakes and just wastes energy. What the Tesla should do in that case is give the warning but take no other action until the brake is pressed a little more firmly. Then it should cut motor power to zero.
One instance she was turning to back up, had her left foot on the brake and inadvertently pressed it pretty hard to hold herself in position while turned around looking backwards, then pressed the accelerator hard to compensate and ended up breaking a lot of brake components. Another instance was lightly resting of the left foot on the brake pedal, keeping the brake lights on and drag on the brakes. Brakes eventually heated to the point where they failed. Another instance of this that wasn't mechanical was where her brake lights stayed on from the light pressure while driving causing a police officer to think her tail lights were not working.
Not saying she's the best driver in the world, but these are very common occurrences with people who drive with both feet in automatics.
I don't have my car right now so I can't check but if I remember correctly there is a tiny bit of play in the pedals before the warning goes off. I'm slowly learning to deal with it. But going into my garage which has only a couple inches of clearance on both sides is tricky; it would be a lot easier with creep on but I otherwise hate creep.
I taught myself the left foot braking technique a few years ago when I got into serious off-road rock crawling with my Jeep. It is nearly impossible to drive smoothly up a rocky slope by modulating the accelerator alone. It's much easier to keep the accelerator almost constant and adjust speed with the brakes. Mind you, we're talking about less than 1 mph most of the time.
If the Tesla had some regen braking at slow speeds this issue would mostly go away.
And if Tesla made a serious off-road vehicle I would be first in line to buy one!
Well, again, I'm talking about regular public road use. The Model S certainly is not designed for "serious off-road rock crawling" use.
Overall, it just seems much better to just drive with the right foot. More efficient (no power applied + brakes applied) and safer (no pressing the wrong pedal at the wrong time, keeping brakes engaged inadvertently, etc).
Edit: Maybe this needs it's own thread.
