MarcG
Definitely going to have to look into this...
Yep I was surprised too. My inner treads were less worn than the inner/outer ones, then I noticed 50 psi and thought I was wrong this whole time with 45 psi - turns out they changed their recommended pressures. I believe the door jam placard also states 45 psi IIRC. If you find out why they changed it, please do let us know!
Isn't it supposed to be every 5000 miles? Or does that not apply to the D's? It was just based on my experience with the previous P85 which I took in about every 5000 miles.
I'm not sure what the recommended rotation schedule is, as it differs between staggered or non-staggered setup, but with the D it seems that it would be less frequent since the rears are no longer the only tires doing all the traction work.
