Andyw2100
After getting to drive with version 7.0 a little bit this afternoon, I have a few observations that I have not seen anyone else make yet.
One is that the release notes are not exactly correct with respect to the speed limit sign. The notes say that the size of the sign increases whenever the speed limit is exceeded. Here's a picture:
In actuality, the size increases when the speed exceeds the speed set via the Speed Assist setting. So, for example, if the speed limit is 65, and you have speed assist set to +5, travelling 70 will not cause the speed limit sign to increase in size, but travelling 71 will.
Also the sign does not remain large the entire time the speed is exceeded. It seems to stay large momentarily, and then that repeats whenever you pass a speed limit sign.
Another observation is that the brake lights remain on if the "Hold" has been engaged, as it will be pretty much any time you come to a full stop and use the brake pedal. So, for example, if you stop at a light, your brake lights will be on, even if you remove your foot from the brake pedal. The brake lights turn off, of course, as soon as you step on the Go pedal.
Finally the parking sensors now show much cooler, more fluid graphics as you are approaching objects. Below is a picture after I parked in my garage.
