Dolby has improved somewhat since .19, but its not carrying a consistent, rich sound. I continue to turn it off. Are you liking it now?I'm curious what prompted Tesla to put effort towards the audio quality again. It's definitely been paying off on UHFS, and based off the above comment, on non-Premium too!
You know how taste-testers eventually loose tastebud sensitivity, well maybe the sound engineer.............nah forget it.
My question to you now is: Do you have some way to force an update so that you get the latest firmware and are able to decipher what's changed? There are only 10 reported through the tracker for this particular FW but you always are able to get the FW.2.32.65 updated the following systems (from 2.32.23):
CID (Center Display)
IC (Instrument Cluster)
Gateway
Audio DSP
When I read it, I thought the exact same thing Art.Boy CuriousG your user name is spot on!
Admit it, you want to know the answer too!Boy CuriousG your user name is spot on!
I don't keep it on consistently but I find depending on genre of music I sometimes keep it on. It's now hit or miss when before it was 100% miss.
That's kind of par for the course for this kind of postprocessing though. Some cars give you a slider for the amount of surround sound effect you want -- generally the settings below 50% are what you want for everyday listening, and cranking it up it either sounds really good or really awful depending on the track.
Nothing new. MS can and does turn on cooling (and heating) to preserve its battery pack's health regardless of your HVAC settings, so there has always been some potential to moderate the cabin temp as a result. If you keep it plugged in to wall power, it will draw from there to accomplish the task instead of using its own battery power.Noticed this:
Car plugged in, fully charged. When I check interior temp, it says 68-70.
I have not set the climate system to ON, nor is the car set for pre-conditioning.
Outdoor temp 80-90
Any thoughts?
Some owners report that changing Range Mode ON or OFF varies when that takes place, but I have not personally observed that difference myself. Also, there have been reports about recent firmware has become more aggressive with actually turning on cabin cooling... bubbles on touchscreen Is one such comment.
Also, it's unlikely that my car is simply ventilating the vehicle versus using the A/C.
There's no way the temp could drop to 68-70 with outdoor temps between 80-90
You're probably just seeing stale temp data in the iPhone app. I bet if you turned on the A/C the phone app would update with more reasonable numbers .
I turned on the climate control and it confirmed 70 degrees.You're probably just seeing stale temp data in the iPhone app. I bet if you turned on the A/C the phone app would update with more reasonable numbers .
