ClearwaterBchSteve
P445 / VIN 1794
You are correct. Here is the sticker from my P85. By the way Hans, your car is beautiful. Congrats! Steve.I think the sticker says the same weight as the 85 kWh cars.
Just got my delivery notice - #9,656 - 60 kWh
Between Feb 17 -March 5
Just a tip: if you want to keep your VIN private, you should blank out the last four digits. Everything else can be deduced from your configuration.
Actually both stickers refer to GVWR, which is GROSS vehicle weight rating at 5710 lbs. That number is max amount of load the car can handle (including all passengers/cargo). This is not the same as curb weight, which is the what the car weighs with nothing in it. So curb weight may not necessarily be the same.You are correct. Here is the sticker from my P85. By the way Hans, your car is beautiful. Congrats! Steve.
Mystery will continue for now...
Still no button for reservation 8040.
I'm overseas and did see three missed calls in rapid succession from 650-240-xxxx
Was that it?
What's the point of keeping the VIN private? Does that protect you in some way?
But wait, if GVWR is vehicle plus cargo, and since the cars have the same chassis and suspension the cargo should be the same, and the GVWR is the same, that means the vehicle (curb weight) is the same, no?Actually both stickers refer to GVWR, which is GROSS vehicle weight rating at 5710 lbs. That number is max amount of load the car can handle (including all passengers/cargo). This is not the same as curb weight, which is the what the car weighs with nothing in it. So curb weight may not necessarily be the same.
http://en.wikipedia.org/wiki/Gross_vehicle_weight_rating
It makes sense for the both the 60kWh and 85kWh versions to have the same gross weight if they use the same chassis and same suspension.
I read GVWR as being the maximum that the car can handle. If the 60kWh and the 85kWh have the same GVWR it just means that the 60's can hold more cargo. It makes sense that the 2 cars have the same suspension.
I don't think it really matters much. But there was some discussion on this earlier in the thread. I just noticed that ClearwaterBchSteve had covered up everything but the last 5 digits.
Congrats, vcor! Yeah, I'm confused by the two pics too...
Btw, hasn't this thread outlived its existence?
The
Let's have the VIN reports and delivery windows/dates here:
Model S Delivery Dates and Sequencing
And the actual delivery experiences here?
Model S Delivery Update
Those stickies have been commandeered by the 85 packers till now; it's time we 60s spoke up over there![]()
I wish someone could put a 60kWh and 85kWh on a scale one after the other so we can dispel this once and for all! I'm sure it will happen eventually...
I've seen them at a scrap metal place and a stone supply place, but they weigh the vehicle before and after to get the change in weight; not sure if they care if the scale starts at zero or not.Someone get thee to a scale. I'd think a waste/recycling center would have one, I've used such before.
Great idea! Although to be perfectly scientific about it, you should probably recruit a friend with an 85 kWh car with the same roof option (i.e. both pano or neither pano) and weigh both cars sequentially on the same scale with no passengers and nothing in the back or frunk. The scale at our local waste transfer station is in really rough shape and I wouldn't be surprised if it was off by a few hundred pounds. You should probably also offer the guy at the gate $5 or something since you probably won't actually be using their waster/recycling service that day.Someone get thee to a scale. I'd think a waste/recycling center would have one, I've used such before.
No. A car with exactly the same body, suspension, and tires (I forgot to mention tires) will have the same gross max load rating. The body/suspension/tires do not care what makes up that load. Think of the body/suspension/tires like a cart. The cart doesn't care if you put motors/batteries/people/cargo etc. into it to make up the load as long as you are under the max load rating.But wait, if GVWR is vehicle plus cargo, and since the cars have the same chassis and suspension the cargo should be the same, and the GVWR is the same, that means the vehicle (curb weight) is the same, no?
