Albert1162
Door started presenting but not opening. Then, it started opening again randomly and finally will not even present handle anymore.
Intermittent "not opening when pulled" is indicative of a wire that is stress fractured internally (completely) but held together well enough by insulation cover so that contact is sometimes make, when the wire is flexed "just right".
In my case, it was also intermittent, with a tendency to work by applying more pressure, until it stopped working at all. But the wires were ok, it was something inside the switch.
If you don't want to mess with all the soldering I can tell you from my recent purchase from Tesla that the microswitchs with the wires already attached cost $30.
1016009-00-CDo you have the Tesla part#? I have a microswitch failure (previously soldered to fix the broken wire, now the actual switch is bad) and would like to replace the part without soldering.
1016009-00-C
After looking at the invoice I paid $38. sorry about the misinformation.Thanks, I stopped in Paramus on Monday and picked up a pair of these. I like to keep extra parts on hand.
They charged $41+tax each.
By any chance do you know where I can purchase that micro switch in America?The microswitches used for this application are Panasonic ASQ series. Can be found at common electronics supply parts places, like Digikey. They're about $5 each.
They make some pre-wired and exact matches for the ones found in Tesla door... or you can order them with lugs and solder your own wires. You'd only need to do this if you damaged a switch while working with it for some reason.
There's not been a clear answer to that. My last broken handle was re-built as goodwill out of warranty. The re-build cost would probably be similar to the $200 extended warranty deductible. Someone recently said they were refused a re-build and had to buy a new unit for slightly more than $500 installed. Early fears were that it was a $1000 replacement. I will soon be finding out as I had another paddle gear break yesterday and I will get it fixed at the first service center that can take me as I head out on a major road trip. If I have to pay $500 for a broken 5 cent part, I'll not be pleased.Very timely... I have that exact issue right now. Fortunately I bought the Extended Warranty literally two days before it happened, so I should be covered. This makes 3 door handles now. Anyone have a guess how much a new handle would cost if we had to pay for it out of pocket?
