Replacing the brake fluid every two years seems obscene to me when EVs use the brakes a lot less. My last ICE car recommended changing the brake fluid every 7 years.
I didn't realize the battery coolant needed changing this often.
There isn't an independent Tesla Autohaus in Oslo yet?
Brake usage has little to due with brake fluid life and more to do with the design of the system.
Brake fluid is hydroscopic and will absorb moisture from the air. That moisture contamination must be dealt with via regular fluid changes. Some vehicles have (mostly) sealed fluid reservoirs will others have vented reservoirs that can allow moisture to get in.
Two years is a common interval on modern cars, although many people ignore it.
