Argoniii
Dis you set the wall charger correctly using the rotary amp settings and have you checked that you have not set a charge limit in your car itself.Just installed black signature wall connector, on a 50A breaker on the sub panel (with the selector pin properly set to #8 for 50A breaker).
According to this chart Wall Connector the Model 3 should charge at 40A and add 37mi/h range, but the car shows only 32A max (approx 28-29mi/h).
Is this right? Why can't I charge at 40A?
