sorka
Welcome to the club. I've had 4 Model S do this to me. All about 90K to 110K miles. It requires an entirely new headlamp assembly at $1200 per side!
Or you could have just replaced the bulbs.
I was going to make a negative post, and then I saw a headlamp for a BMW X6 that cost $2500... but Tesla won't sell you just the Xenon bulb?
But in my poking around, I found this:
Oracle Lighting® - High Output LED Headlight Conversion Kit
anybody tried it?
anybody tried it?
Why would they need to? You can buy the bulb in any auto parts store or on Amazon if you want to save money.
Read the fine print - "with Factory Halogen Headlights". Not a direct replacement for the DS3 HID headlights.
Yes, you're right. I didn't even realize the model S came with 9005 halogens. I couldn't find a HID to LED conversion on that site, but found some on others. My Xenon's are fine but I may investigate this further if I get a little time...
So I replaced the bulbs with the recommended bulbs from the member off of Amazon.Any update? I'm about to do the same.. replacing the bulbs.
The way it was going out was very interesting. It would or would not turn on when I first get in the car. If it was on then it would soon flicker off. I would then manually turn off the lights and then turn them back on and then the lights would start working. Most of the time after that it wouldn't go off again but it did occasionally.does this happen consistently, every single time? wonder if it's a bad ignitor/ballast? have you tried swapping the known working xenon and trying?
I actually asked the Tesla Service Center about replacing the bulb and they didn't know what I was talking about. I think they just replace the whole lamp.
The biggest pain in the butt was removing the tabs from the wheel well. It was even a bigger pain in the butt putting them back in. It was worth it as not to spend over a $1000 for a replacement.
The new bulbs have worked fine without any further issues.
I do feel the new bulbs (the $35 from Amazon) are not as good as the OEM bulbs but still do a good job.
I just did the bulbs for now. Love the extra illumination and the slightly whiter light. They have been working perfectly for a couple of months except one time when one went out once. I turned the lights off, then on, and it worked again. So I assumed it is the ballast going. But yes, to answer your question these bulbs work fine with the OEM ballast.Thanks for the link, looks like they are still on sale. Curious if you had to replace the original 35W ballast with the one that came with the 55W bulbs? It seems that replacing just the bulbs is much easier and could be done through the wheel well without removing the headlight assembly (and thus the bumper) but I don't think you can do that if you want to replace the ballast as well. Thank you!
Thanks so much for replying, I will do the same - just change the bulbs and see how it goes. I had a ranger come to my house for a door handle and he said you cannot change the ballast without taking off the headlamp assembly (and thus the bumper) so if I don't have to do that I will be very happy.I just did the bulbs for now. Love the extra illumination and the slightly whiter light. They have been working perfectly for a couple of months except one time when one went out once. I turned the lights off, then on, and it worked again. So I assumed it is the ballast going. But yes, to answer your question these bulbs work fine with the OEM ballast.
It is definitely a bit of a pain as they are not plug and play. There are plenty of videos of guys upgrading their stock lights to HID kits, most put the ballasts inside their engine bay, but I saw one where they installed the ballast inside the headlight; I will probably do that. The issue with the model S is the OEM ballast will need to be reinstalled just as a plug to keep out dirt and moisture. Don't mind the procedure though, when looking at the price of the OEM ballasts. I am going to wait until spring to do this, as winter is upon us here. Taking the ballast apart, cleaning it and reinstalling seems to have given it some extra life though, because the lights haven't gone out lately.
Curious where exactly is that ground stud located?1. The DS3 HID bulb units are replaceable.
2. I had the passenger headlight go out intermittently and then permanently. Nothing wrong with the light, it was a broken ground stud on the frame. See here: Ground Stud
It tells you in that link you quoted:Curious where exactly is that ground stud located?
Super weird, my 2015 was doing this also for a week or two, then now nothing for past 2 weeks?I am the only person in the world that has this problem? I feel totally unique right now... Anyone have any insight as to what might be happening?
Thanks. I'll be doing the same. 10yrs/130K miles seems like a reasonable life for the bulb. I'll report back if it persists with new bulbs.I just replaced my wonky bulb recently that cured it for me. Didn't have to replace the ballast.
Left headlight bulb and ballast replacement, hopefully not a wiring issue
For months I've been getting a left headlight malfunction detected. This would happen very sporadically maybe once every week or two. I even got pulled over getting off the NY Thruway to get to the Hudson NY Supercharger. In Lights I hit Parking, then On and it fires right back up every time...teslamotorsclub.com
Just replaced my intermittent left one with a $15 bulb from Amazon last weekend. Not too bad a job. I have a hard time telling the difference between the old and new so I'm just changing the one for now.Any updates from anyone who replaced their bulbs? Anyone with reoccurring headlamps shutting off? My left headlamp started shutting off about 18 months ago and can go months without an issue, but last night it seemed to malfunction every 8 minutes or so.
