cpa
Tesla is using the one-size fits all mentality for this recurring problem. Someone really ought to parse all the data from all the Superchargers and determine how and when to apply this 80% limitation. Then make it so the charging bar cannot be increased to a level >80% at times.
It seems to me that frequency of usage boils down to geography and time of day. Superchargers in urban areas should be capped at the 80% limit for all comers except for the wee hours of the morning when it is odds-on that there is or will be no congestion. Those traveling (not living within) through these urban areas will have many opportunities to recharge elsewhere 60-100 miles away. It may be a bit of a hassle or an inconvenience for them, but we must think of the greater good afforded by this limitation. It only hurts for a little while!
Superchargers that are in remote areas generally should not have this restriction, or the slider should be enabled to charge >80% if it does appear. Bad weather, side trips, smaller batteries, towing, and other drains on the battery necessitate a higher charge at times. And there will be those isolated incidents when a number of stalls are down or during popular heavy travel times. Tesla has enough of these data to be able to program these limitations during the appropriate conditions.
It just seems to me from these anecdotes, that someone ginned up a facile software solution without drilling down into the detail and determining how distance and usage affects the ultimate charging levels that people feel they need to continue their journey.
I can hear the catcalls and other complaints when inexperienced drivers stop the charge at 80% and continue on their trek only to see suddenly the nag on the screen to keep your speed below 65 (or 55) to reach your destination.
Finally, I offer a real-life example from smack-dab here in the Valley: Along SR99 between Sacramento and Bakersfield, Superchargers are at Manteca and Fresno. Manteca to Fresno is about 110 miles. No problem. To continue east from Bakersfield to Barstow (after charging in Fresno) and either Interstate 40 or Interstate 15 requires a stop in Mojave, about 180 miles from the Fresno Supercharger and 220 rated miles per EVTripplanner. If one were to rely upon the 80% rule, and if one were to utilize the in-car charging routine, one would be routed to Kettleman City or the Bakersfield - I5 Supercharger before being able to head east across Tehachapi Pass on SR58 to Mojave. Yet, a 90+% charge at Fresno will reach Mojave satisfactorily with about a 10% reserve in an 85. The additional driving, charging, and rerouting to Interstate 5 adds an hour or so, yet charging to 93% adds maybe 20 minutes of charging.
