Andyw2100
Did I just hear that the Model S has a timer/control to both start charging when Time-of-Use is favorable, and to limit the charge rate (so not to blow an undersized breaker). I can't find a source for the timer question.
OK - so I CAN start charging whenever I wish, and at a rate I wish. Can I also turn off the charging just before the rates spike?
I see you have received some responses to these questions in this thread. Some are correct, some are incorrect, and some are incomplete.
I had answered a similar question you posted in another thread here: Reservation tracker for Model 3
Here is part of what I wrote in that response:
The Model S does allow you to plug in, and set the time when you want the charge to start, and in all likelihood the Model 3 will as well. But what I mean about being careful about what Desert Driver may have been asking, the Model S does not allow for a feature I have seen requested, which is for true Time Of Use (TOU) tables to be entered, and then for the car to only charge intelligently during the low rate periods. For example, the feature I have seen requested might have a low rate ending at 7:00 AM, and then starting again at 5:00 PM, and the user would like the TOU charging system to stop the charge at 7:00 AM if it has not completed by that time, and to then resume it at 5:00 PM, when the rates are low again. The Model S --DOES NOT-- have a system that allows for this, so if that is what Desert Driver meant when he asked about a TOU charging system, then the answer would be no.
Again, we can plug in, and delay the time the charge starts. It is also pretty easy to make the charge end at a given time by setting the charge level and estimating how fast the charge will occur. So if you knew that after 1.5 hours you'd be getting into a higher rate, and wanted your charge to stop before then, you would just adjust the state of charge percentage that you were shooting for such that the car would finish charging at about that time. Just please be careful and don't call this TOU charging, because I believe the people looking for that feature want to be able to enter a table of times and then have the car start and stop charging as needed such that it charges only during the low-rate times
