You're also contracted to keep it for 3 years under the OLEV grant so can't move before then if you intend to remove it (although I've not yet heard of the OLEV enforcing this).
I used my OLEV grant for my current Zoe to install it at a rental property. Will be granny charging the Model 3, unfortunately.
My understanding is that, if you have moved home and have a new vehicle you can claim another grant. These were the only questions on my OLEV eligibility questionnaire related to previous use of the scheme:
That's great to hear. Unfortunately the new property I'm in at the moment has a garage, but it's detached and further than 10m away from the box.
There's a double socket in the garage so will just granny charge over night and at the local Ecotricity point if more urgent - not too much of a hassle.
Does that mean I can use knowledge to charge to my car?On balance knowledge is power surely?.
It's a detached house so freehold,
Just another thought, what would be involved in installing a 32a commando?
Thats not one I’ve heard! The general rule with battery charging is the slower the better, as it doesn’t heat the battery as much. The only downside I can think of using the UMC all the time is that you might wear it out or damage it, and a new UMC costs more than a charger!(side note - I've heard rumblings that you shouldn't always just granny change, not an issue as I'm not far from a rapid CCS and a supercharger, but still - is this true?)
Consider a local sparks running a line to a sub-box in garage.
i did that here for my barn mounted charger and took the opportunity to put a couple of waterproof outside 13A sockets for car cleaning and spur off the router - all on overhead cable.
This is accurate, but nevertheless worried me enough to call in an engineer from Western Power (which was free, but still time consuming). We had a 60A fuse which he swapped for an 80A just to be extra safe due to us having electric underfloor heating in 2 bathrooms (that we never use). He figured that as we had gas central heating and hot water (combi) no immersion heater, the only other significant load was oven, hob, kettle, iron, tumble dryer, washing machine. He said 60A would have been fine for a 32A EV charger in addition.Have you checked the size of your main fuse. If you only have 60A, that may also scupper you unless you can get it upgraded. Ideally you want a 100A main fuse, but 80A may be workable depending on personal factors like heating and cooking.
COMPLETELY AGREE. This will become a major selling point for rental properties.Given you're offering to pay for the installation and leave it in situ when moving out, I think your landlord would be bonkers to refuse. It's adding value for him for free!
Would I be able to install a charging point there?
This is where I see the whole pain of the DC tripping RCDs falls apart, unless someone can educate me (@arg ) If it's a commando or regular 13A socket then the socket doesn't know you're plugging in an EV, so in which case there isn't always going to be a very expensive breaker. This feels like a gaping hole from the IET regulations, diligent people will jump through the hoops, I guess many electricians may not be aware, I will (have) waste hours trying to research this..
Check out Baldrick's spreadsheet
EVSE Options
look up the install guides for the charger - most of the installation guides say something about fixing to a solid surface of described dimensions. Suspect Wiring / Building Regs may give guidance.
Some tethered cables are fairly long so maybe reach from your house wall rather than a fence.
If you're near the M3 Fleet then maybe a drive to a nearby supercharger and save yourself the effort at home
You’re right here. Solely relying on superchargers is not a good idea in terms of long term battery health. There have been instances where Tesla have remotely limited the maximum SC current on particular cars because they have noticed excessive supercharging, in order to help with battery longevity. You also need to be charging the batteries up to 100% say, once a month, to balance the cells.I live really close to the Fleet services and I pass that every day almost. I read stories that it's perhaps not the healthiest for the battery to rely on superchargers? Also is the fleet one open yet I'm sure it still says "soon"
