If the nomenclature is the same as I'm familiar with, which I suspect, the first 7 digits is the part number, the following two digits is the variant number, and the letter is the revision.
You usually swap the part number when you have a sufficiently different part, the variant goes -00 -> -01 -> 02 etc, whenever you need a slightly different variation of the part. Like if you needed one part with one tinting and one with a different tinting. Then the revisions are improvements, so C is better than B, which is better than A, etc. (But a revision may not matter at all. It could just be a correction of spelling on a some specification.) Assuming the part numbers are assigned sequentially, the chronological progression of the parts numbers would be something like this:
1034385-00--
1034385-00-A (?)
1034385-00-B (?)
1034385-01--
1034385-01-A
1034385-01-B
1034385-01-C
1034385-01-D
1034385-01-E
1034385-01-F
1034385-01-G
1034385-01-H
1066747-00--
1066747-00-A (?)
1066747-00-B (?)
1066747-01--
1066747-01-A
1066747-01-B
1105964-00--
1105964-00-A
1105964-00-B
In this scenario, the "best" part should be 1105964-00-B, but it's not possible to say for sure. They could have started designing 1066747 before they started 1105964, and then finished it after 1105964. Then the lower part number is the newer part. Or they may assign part numbers non-chronologically. Or any number of possibilities.
