android04
There are heated covers that are wireless as well. They have a small rechargeable battery and USB cable that you can plug in to charge when it's parked.I man up and buy a heated cover for $25 on Amazon. The wire is annoying, but I only use it when necessary.
I only have my Model 3 right now until my Cybertruck arrives in Spring of 2022, so I can't spare it to take the steering wheel apart. But if I could, I would probably design a replacement steering wheel that has heating elements built-in and turns on with the rear window defroster controls (which also turn on the side mirror heaters). It would have a small LiFePO4 battery to power it so it would be cordless until you have it parked and plugged into a USB port to charge it. Or better yet a MagSafe type magnetic charging interface instead of an actual USB port.
Then again, by then there might be aftermarket options. Or if the new Model 3 has the heated steering wheel it might not be too difficult to retrofit.
