What makes you think that (a) Tesla has HD maps of any sort deployed and being used in production, and (b) either AP1 or AP2 are using maps? I think they don't (yet) have HD maps (or anything close to it outside of their R&D labs) and if APx is using maps/GPS at all (beyond speed limit and road classification) I think it's a pretty primitive attempt to slow down in advance of a curve, and I think even that is speculation at this point.
I would be thrilled to be shown to be wrong on any of those points.
Just to avoid any terminology confusion: I'm using the term HD maps to describe digital maps that are higher resolution than the classic NavTeq style maps that describe roads in terms of curve parameters and centerlines. So any map that, for instance, has separate lane centers for each lane and which reports lane centerlines at a frequency higher than just what is needed for curve description would be an HD map in that definition. I might be using the term incorrectly, I'm just following the term use as I understand it. There's another, different, way the term gets used that seems to come from originally from Google where they mean a map that is generated from lidar records and which provides a centimeter resolution topological representation of the entire path. I have not heard anything to suggest that Tesla is doing this second activity and, in a sense, it doesn't work for their use case so I'd guess they won't go that route. As for the former, Tesla executives made representations regarding generating what they were calling high precision maps back when AP1 was first introduced. I just did a search to find an example and noted that I couldn't find examples of those statements more recently, so maybe there's something to the notion that they changed their approach.
You've probably seen this image, it's from a Tesla presentation:
This showed up in a couple of different autopilot presentations back in 2014/2015. The left frame is what I described as NavTeq style data, the one on the right shows much higher resolution including individual high resolution lane metrics.
It's possible that they don't actually do that I suppose, but they definitely use some kind of beyond NavTeq map data because I've often seen my car respond to things that can't be seen from the forward camera or radar - like anticipating and slowing appropriately for a blind curve on a road through a tunnel of trees. When I say appropriately I don't mean that it just slowed down - earlier versions of AP1 would do that, but later version of AP1 would match the entry speed of the curve to the unseen curvature of the upcoming bend. At first I thought maybe it was reading warning signs but I found that the behavior did not correlate to any signage. It slows to different speeds depending on the curve. It's not always right on, but it performs much better than chance would allow. I remember quite distinctly when this capability showed up because it dramatically changed it's behavior on some routes that I drive frequently.
Anyway, that's all I have to support my belief that they are using HD maps - in the past they've said they are, and I see behavior that I can't explain without using GPS/maps. Just like everyone else here, Tesla is mostly a black box to me so I could be wrong.
