I'm going through the process at the moment. 24 units in the apartment, 24 carports and laundries on the ground floor, 12 units on the first floor and 12 on the second. with 8 units per stairwell. My meter board is with 4 others (3 other units in my starwell and a common area, with the top 4 units having their own meterboard on their floor. My fuesbox is internal to my unit, in the 3rd bedroom. That means there are 3 separately metered common areas, and 24 separately metered units.
I've been quoted $1500+GST for a new 32ish amp single phase circuit to run from my fusebox, through the wall to outside, and in conduit down to my carport, where I'll place it near the outer side for maximum flexibility. There'll then be an isolation switch inside my laundry so I can minimise others spotting the wall connector and stealing power. There may need to be a second isolation switch beside the WC, but I'm not sure of the legalities around that.
I had a new smart meter fitted last Friday, so I can hook into off peak tariffs. The sparky on Friday said there are 3 phases entering the meterbox, but only 1 going to the units. To upgrade the charging circuit to 3P would be more wiring from the meter box to the fuse box to the WC. That will more than double the price I reckon, so not worth it at this stage.
I'm still waiting for approval from the Body Corporate committee, so I can't proceed with the rest of the install yet. I'm hoping soon.
