So how does the iPace compare to AWD Model 3? (Road trip driving aside)
Two different kinds of cars. The loaded Jag has some Off-Road features, more room, more amenities than the Model 3. And more money. It will be in Australia before the Model 3.
It would be more fair to compare it to the Model X 75D. When equipped the same, the iPace is $10,000 less, but both are pricey. That means adding paint, deluxe interior, PUP, AP2 to the Model X 75D, but the i-Pace would still have more features, and the X would have more room.
That's what Jaguar would like you to think.
The fact is, the iPace is the same size as the 3, except four inches taller - still five inches shorter than the X, along with being several inches narrower and more than a foot less in length. There's no way the iPace is closer in size to an X than a 3.
It's true that we haven't seen a 3 with air suspension to raise and lower yet and the AWD version only just became orderable, kinda like the iPace.
inch MX M3 i-Pace
Wheelbase 116.7 113.2 117.7
Length 198.3 184.8 184.3
Width 78.7 76.1 79.2
Height 66.3 56.8 61.6
Between the 2, I think the iPace is closer to AWD M3 than MX.Two different kinds of cars. The loaded Jag has some Off-Road features, more room, more amenities than the Model 3. And more money. It will be in Australia before the Model 3.
When SAS is available for M3, will be interesting to compare ground clearance & ride quality.
+1...I-Pace is not a large vehicle....it's actually smaller/not as tall as the Macan (which my wife drives and I find small). In fact, the Model 3 has similar dimensions.
Spec I forgot:
Rear cargo:
And it has a frunk.
- 25.3 cuft with 5 occupants.
- 34.4 with 4
- 40.0 with 3
- 51.0 with 2 occupants.
If you see their electronics/power platform, it explains whyI am surprised the frunk is that small though.
Your dimensions are wrong. I pace width without mirrors is 74.6, with mirrors 84.2It's not as big as a Model X, not as small as a Model 3. While it uses some of the Land Rover off-road tech, they seem to focus more on the sport aspect of the car. They let the press run laps around a road course, as well as an autocross style track, but I have not seen any footage of it actually in the dirt, only an approach/departure ramp test, it appears to climb like a goat. It has good approach and departure angles, 'creep mode', can ford nearly 20" of water, but also hustles through mountain roads like a sport sedan. It's about the same weight as the Model S 75D, but more powerful and cheaper when equipped the same.
I guess we will see. Hype dominates the EV market.
Code:inch MX M3 i-Pace Wheelbase 116.7 113.2 117.7 Length 198.3 184.8 184.3 Width 78.7 76.1 79.2 Height 66.3 56.8 61.6
Wiki has the same numbers I do. I used the same source for all info. Remember things change. The i-Pace Concept was shown in 2016. Production starts in July (claimed), customer deliveries to the US in October. As of February, the i-Pace has run 1,500,000 test miles so far. These often evoke changes.Your dimensions are wrong. I pace width without mirrors is 74.6, with mirrors 84.2
Perfect place for your EVSE and work gloves, or perhaps chains. That's where the charge port is.What the frunk!
If the I-Pace is sort of Model 3 size (with a bit of Model X chucked in) why is it so heavy?
