This is the one thing that concerns me about the Model S. I will frequently use it to get to our cabin in the mountains, where there is no grid power. Only solar, which is too small to charge the S, and a Honda EU6500iS generator which I want to run as little as possible.
I will probably mostly arrive with 50-60% SOC remaining and might stay for up to 5 days in temperatures as low as -20degF in winter. I have taken the Leaf several times and it uses very little power in that scenario. If the battery gets down to -4degF or so it will use the 300W battery heater to heat it to around 7degF. At this temperature it is nearly impossible to charge the Leaf (charging power was down to ~500W at ~83% SOC) but driving was no problem at all. No regen for a while of course.
If the Model S attempts to keep the battery at an optimal driving temperature all the time I will have to run the generator a lot every day. That I seriously want to avoid. What I need the car to do is get to a "deep sleep" state where most electronics are powered off (I don't car if the screens take 2 minutes to boot up) and the battery temperature management only keeps the battery as warm as it needs to be to avoid damage. In the event that I suddenly have to drive the car I don't care if I have no regen and the power is limited to 50kW.
When I want to leave, after say 5 days, I'd ideally power up the generator for an hour or so, then waking up the car and letting it heat up the cabin and battery to optimum driving temperature (preferably with full regen as it is an hour of downhill driving first). The generator can deliver 24A@230V (5.5kW) continously which should be more than enough.
So here's hoping for a future "deep sleep/storage mode" software feature before I have to configure my car. I guess quite a few others also would like this fetaure.
